How do I remove the front sprocket
- aus636
I cant remove my front sprocket on my zx6r 05 I have tried a air impact wrench and a braker bar. I have someone on the back brake and it is in 1st gear. I cant move the nut.
- Rossi
Re: How do I remove the front sprocket
1stly.......You have folded down the locking washer ???
2ndly.....The b'stards are tight
get a bit of scaffolding pole to fit over the breaker
3rdly..... big lump of wood(wrapped in cloth to protect paint) through the back wheel against the swingarm
I have the same problem on Mel's 636 !!! It is without a doubt the tightest sprocket nut I have ever tried to undo.
If you find a solution, post it up - I am going to go into battle this week with a big fuck-off rattle gun, if that doesn't work, I intend to make a wheel attachment device to the Prado, hook up 4WD while its on axle stands, and use the torque of a 3.4L motor to undo the fucker !!!
you need a big bar on your shifter....or just pop the bike into a kwack dealer and get them to do it, and change the front sprocket there....cost f'all.
- aus636
I like the bit of wood through the rear wheel. Do you think there is any chance of damage doing it this way.Rossi wrote:1stly.......You have folded down the locking washer ???
2ndly.....The b'stards are tightget a bit of scaffolding pole to fit over the breaker
only if you use oregon or any other soft timber......use a piece of 4" x 2" hardwood, and it won't be damaged at all !!
- aus636
Thanks I will try the using the piece of wood
- MadKaw
- Administrator
Go to Kennards (or whatever hire place is up there) and hire a big electric rattle gun. More power than most air ones and costs about $15 for 1/2 a day...
Gosling1 wrote:only if you use oregon or any other soft timber......use a piece of 4" x 2" hardwood, and it won't be damaged at all !!
robracer wrote:Gosling1 wrote:only if you use oregon or any other soft timber......use a piece of 4" x 2" hardwood, and it won't be damaged at all !!![]()
thought you could sneek that one in
- Team Naked
If all else fails, cheap wine and a 3 day growth (Cold Chisel)
- 6maniac
- Bike: Z750
Old motor mechanic's method (sorry Possum) " If it don't fit, use a bigger hammer ! "
