any tips for LONG STORAGE
ezydeek
Post by ezydeek »
im heading to LA for almost 6 weeks for a hoilday and was hoping if anyone can give some tips on what to do with the bike for storage.
my main corncern is not to let the battery go flat, any good battery charger out there?
what about tyres, fuel, spark plugs?????
any advice would be great
DONG 1. v & n; TO hit or punch "Watch it, or I'll DONG ya!" 2. n: A penis "Good lord, my dong is huge!" also slang for 'DILDO' or DOUBLE-DONG
DONGA. Ratherly larger than a dong
Re: any tips for LONG STORAGE
Did someone ring??? 8)
Go to Super Cheap Auto and buy one of these (under $50 from memory) ------------> http://www.master-instruments.com.au/pr ... FJ012.html
For the battery side of things, all will be good - trust me ;)
Frank
Post by Frank »
red_dave wrote:Did someone ring??? 8)
What the hell would know about batteries CHAMP ;)
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
ezydeek
Post by ezydeek »
with this automatic charger you just connect it to the battery and leave it turned ON for 6 weeks?
ezydeek wrote:with this automatic charger you just connect it to the battery and leave it turned ON for 6 weeks?
Yes...
It comes with a ring terminals which you permanently attach to the terminals. The attached connector can just pop out the side of the bike and plug into the charger when the bike is stored.
It's a 3 stage smart charger which you can leave connected forever basically.
frl0173 wrote:What the hell would know about batteries CHAMP
I know enough that you also need one of these chargers seeing as you ride your bike less than i ride mine.... CHAMP :lol:
As well as Battery, tyres and fuel are the main concerns.
Run the bike out of fuel if you can. I usually siphon as much as I can out and then ride around the street in front of the house until it runs out. This is good to practice your slow speed control
Tyres don't like sitting on concrete for lond periods. Best method is to leave the bike on stands, but failing that put mats or carpet off cuts under them.
In 6 weeks nothing else should be a problem. My race bike has been known to sit longer than that.
jl4049
Post by jl4049 »
Drain the tank, use the drain screws to empty the carbs, if FI just start it and run dry (wary of this as FI system fuel pumps don't like being run dry too much), and as Photomike said, put it up on stands if you can, and throw a sheet over it too keep the dusrt out.
C1 ZX9R
Rossi
Post by Rossi »
I have always filled my tank to the very max........no air = no rust !!
smart battery charger a good idea, and get ya tyres off of the floor .....race stands ;)
and a bike cover so you don't have to wash it when you get back......6 weeks covers it in dust :shock:
swabio-ACT
Post by swabio-ACT »
Tip of the day is..... lend ya bike to swabio.... and it won't need storage ;)
Slow and wobbly
Post by Slow and wobbly »
6 weeks?
Take the key out of it and that would be about it.
ezydeek
Post by ezydeek »
well... atleast i got a rear stand, i got some old off-cuts of carpet to put under the front tyre.
i heard that you should deflate the tyres so it wont cause any flat spots on the tyre?? is this true?
with the fuel, is it possible to still have some fuel left and i can get my brother to start it every 2 week??
flat spots only occur if you leave it on concrete as the chems in the concrete slowly eat away at the rubber.
Race stands and carpet = fixed
+1 for what Rossi said. I have been told to fill the tank all the way to the top to aviod rust. I know the boys over sea's fill it to the top when they winterise their bikes.
jl4049
Post by jl4049 »
dont give it yo your brother to start every couple of weeks unless he is going to take it for a ride and warm it up properly, or you will end up with condensation in the oil, I get it from time to time int he winter with the shortish runs to work and back.
C1 ZX9R
Burky
Post by Burky »
photomike666 wrote: In 6 weeks nothing else should be a problem. My race bike has been known to sit longer than that.
Race bike :shock: My 10 lives in the garage just as long :oops: but yes the carpet and stand is the best way ;)
Don't let the tyres down, there is no need. Just check pressures once you are back.
