zipper broken down need help
well....... ITS BROKEN DOWN AGAIN *tear* got up this morning all happy that i have a road worthy and going bike again and ready to go to work... and the starter motor is stuck or something... after half a hour fiddling with it. nanna manages to make it go using the secret art of poking it till it went.... but now the damn thing is turning over and just not going... its got fuel its got spark its got air... dad even sprayed some starter helper thing in the air box and still no luck.
so if anyone has any ideas would really help alot.
new update is we have everything back to how it was last night and the night before the bike should be running... like i said above its turning over fine... but just refuses to start.
- photomike666
Re: zipper broken down need help
How many times have you had the tank off? If it's like the ZZR there is a breather hose under the tank, if it gets kinked/pinched/breathed on wrong is stops decent fuel flow...
If you tried lots of things to start it, it may have soiled a plug.
not sure about that breather in the tank.. but due to the fact that ti seems to have plenty of fuel in the fuel filter we don't think its the starved of fuel.. and we pulled one of the plugs out and tested on the bike to see if i was sparking it is. so even if only that one is working it should start.. and run shit but start all the same
thanks heaps for you imput but still might need alot more
- Team Naked
Tried push starting? At the risk of stating the obvious, bike is in neutral, clutch in, sidestand up? Fuel is on.. kill switch is on...
Rusty
Not necessarily. If the hose is kinked, or if there's a vacuum lock, the fuel may not travel through even when there's fuel in the filter.binther wrote:but due to the fact that ti seems to have plenty of fuel in the fuel filter we don't think its the starved of fuel..
push starting didn't work.. and no kink in the fuel line as i said i had taken the bike for a 10 minute ride the night before... and nothing had changed from that... current idea going around is the poor carby has shat itself.... so again sunday or monday the doner bike gives up a carby to test this
thanks for the input
lets hope the carby transplant works
well lucky one of the old man's mates pointed out that this had happened to him in the past looks like dad had ajusted the choke on the bike until it had filled the entire thing up with fuel.. the pistions and after turning it over... we had pushed it into the the rest of the engine... so looks like we had to drop the oil.... at this point which was mostly fuel out and give it 48 hours to breath and dry out.. hopefully this will fix it
Rusty
I heard something a bit different - to do with float levels!
i hear alot of things... but with my story i get to blame dad.. he feels guilty and hopefully will just fix it this time instead of waiting around for me to be there... this means i can't mess anything up
looks like it was the prim... so note to everyone don't leave you bike sitting over nite with prim on haha
we drained the bike replaced the filter new oil and more fuel and what do you know away she goes
yay *Dances* so it looks like im back in business its wonderfully down end now purrs and has more power then i can remember is alittle weaker high end i would like to thank sally for pointing out whats wrong rusty for laughing at me,
nanna the master repairman
oh well looks like he ecan go back to making redectors now
Rusty
Any time, mate, all part of the service!
- Sulli
Who the fark is this sally blokebinther wrote:looks like it was the prim... so note to everyone don't leave you bike sitting over nite with prim on haha
we drained the bike replaced the filter new oil and more fuel and what do you know away she goesyay *Dances* so it looks like im back in business its wonderfully down end now purrs and has more power then i can remember is alittle weaker high end i would like to thank sally for pointing out whats wrong rusty for laughing at me,
some old bloke apparenty who once dropped me bike
haha
haha
