I only lubed up the chain a coupla days ago so its not the dry chain noise ..
Now, have been pretty constantly adjusting the chain after every two or three rides due to it slacking off .... Also, noticed today that the rear sprocket has a little side to side movement that I dont thnik has been there before ... approx 3mm ... is this normal?
I know there should be a little for-aft movement with the chain-dampener thingy, but not side to side ..
Would this be that I put something in incorrectly last time I took the back wheel off?
