GPX250 Suspension
Moderator: Six Addict
gpxpunk
GPX250 Suspension
Post by gpxpunk »
Hi all,
Anybody know of anybody putting in harder suspension into GPX250's, due to shitty stock ones. also pricing if any.
Dave :twisted:
1987 GPX250R. memories
2002 ZX7R . sold!!!!
Re: GPX250 Suspension
80 cents for the preload and $10 for heavier oil.. :-)
Remove the fork caps, drain the fork oil and replace it with 20 weight oil (I think its 15 std).
Before you put the caps back on, put 2 or 3 20 cent coins as spacers on top of the spring washers (under the caps).
This will increase preload and damping on the forks, which, I think, are way to soft std...
Thats what I did to the wifes gpx and zzr250.
The rear.... you will have to get the shock rebuilt if its a problem, but I've found the front to be the biggest problem.
gpxpunk
Post by gpxpunk »
MadKaw wrote:80 cents for the preload and $10 for heavier oil.. :-)
yeah i know the front end is getting done very soon, but yeah my fat arse makes the back end too low and soft, had a real bad problem keeping traction on sunday on the way to from pits, kept jumping around, and bottoming out on me.
gpxpunk
Post by gpxpunk »
Do i need to replace seals or anthing?
Team Monster
Post by Disco »
gpxpunk wrote:Do i need to replace seals or anthing?
I have a treadmill for sale if your interested? ;) :lol: :lol:
gpxpunk
Post by gpxpunk »
hahaha, yeah already got one of those, and a rower and a bike and weight station and free weights and ab machines and a few other goodies. it always helps when your a trainer. :twisted: ;)
MrWasabi
Post by MrWasabi »
how did Jus or yourself find the front end after 20 weight oil and 3 20c pieces in the forks?
Ive got the rear on the hardest setting and im good with that, but i do find the front very spongy...sorry for hijacking the thread..
Mistakes:
Much better, but its still a bit soft.....
Although I did put 15w oil in the front as I had some laying around.
20 w would be better and I may even through another 40c at it.. :-)
MrWasabi
Post by MrWasabi »
Cool, sounds like i have a weekend project :D
Mistakes:
gpxpunk
Post by gpxpunk »
i have no adjustment in the back, but if the zzr rear suspension does, can the zzr rear suspension be swapped in my gpx250?
gpxpunk
Post by gpxpunk »
Found a adjustable zzr250 shock on ebay so hopefully i get it then set it hard for my heavy arse, and should be all sweet. :lol:
Hopefully be all good for next pits sunday ride{23.11} :twisted:
All fun, and hopefully have the front done and sprokets and new chain, haha i have all the parts just no time and the bro {mechanic} is worse then me for time coz i have no idea on that shit, SO I NEED HIM TO SHOW ME THE WAY. 8)
Daisy
Bike: GTR
Post by Daisy »
Yes, the ZZR250 shock is a bolt in swap - but it is about 10mm shorter. My skinny arse didn't have a problem with that.
gpxpunk
Post by gpxpunk »
Daisy wrote:Yes, the ZZR250 shock is a bolt in swap - but it is about 10mm shorter. My skinny arse didn't have a problem with that.
thanks for that, yeh thats good, but ill have to set for its hardest setting, cant wait lol
spacer??
Daisy
Bike: GTR
Post by Daisy »
Dunno how you'd space it - through bolts top and bottom.
