Hi, I have a 1998 zx6r and recently it has been getting flat batteries and therefore not starting. If I jump start it off another battery it always starts. Has anyone else had the same problem?
I have tried using a new battery and it still has the problem. I have narrowed it down to the charging system as it is not pumping out 13+volts when running (used multimeter)-its reading 11volts when engine running.
So its either alternator/stator or voltage regulator, can anybody assist me in where these are located and if possible how to get to them and test each... Any help would be good
Trent
starting problems zx6r-electrical
Re: starting problems zx6r-electrical
Also is there any bike mechanics in the Penrith area who could fix this problem?
- red_dave
- Team Kuda
You could Battery World in Henry St to check it out for you...
There's also Kelen Kawasaki in Penrith.
Yeah thanks mate ill go have a chat to them on Monday, but if anyone knows the location of the regulator that would be good.
