zzr250 timing
zzr250 timing
Hi There.. I need info on setting the timing on a 91 zzr250 . I believe the 2T mark must be in the view hole and need to know where the EX and IN marks are to line up on front and rear cams ( i believe there should be 33 camchain pins counted between these marks also) any help on this would be appreciated.
- Cwidova
Re: zzr250 timing
have a look for the supplement manual on the web, from memory it should be in there.....also remember something about the cam marks have to line up with the top of the head, but that is about it!!!
'06 ZX6R
'10 FE390
'10 FE390
Re: zzr250 timing
Hi thanks for reply i found the complete procedure and pics at http://forums.ninja250.org/viewtopic.ph ... ght=timing
