Looking for some tips here folks.
Right managed to get the bike built up to a level where i can start and run it.
Let the bike run for a while to see if the fan would kick in and it didn't. Turned it off and yo could hear the thing bubbling through the expansion tank (if thats the right word lol)
Anyway i was thinking that it was either the fan its self, thermostat or temp sender.
So where does the fan get its feed from for cooling the radiator??
Radiator fan not kicking in - 1996 ZX6R
- Sulli
Re: Radiator fan not kicking in - 1996 ZX6R
Did you bleed the cooling system first
wullieb1
- Bike: ZXR750
Did't drain the coolant system bud.Sulli wrote:Did you bleed the cooling system first
Was only plastics and the ignition module i changed over.
Didn't start it as it didn't have the exhaust fully fitted
- Sulli
So where does the fan get its feed from for cooling the radiator?? it comes from the switch on the rad left side just cleaning the contacts usually fixes
wullieb1
- Bike: ZXR750
Cheers bud.Sulli wrote:So where does the fan get its feed from for cooling the radiator?? it comes from the switch on the rad left side just cleaning the contacts usually fixes
I'll have a looksy at the weekend.
wullieb1
- Bike: ZXR750
Cheers bud.Sulli wrote: it comes from the switch on the rad left side just cleaning the contacts usually fixes
Cleaned the contacts and had a play with the connector and its working fine now.
Gav
- Bike: Don't have one
My fan was working fine, then I changed my coolant...Guess what.. fan not worky..Mate I tried fiddling with the connections and it did work ,sometimes. I'de suggest a new fan switch. End of prob. cheers
