http://www.youtube.com/watch?v=wDZv7FlY ... re=related
I came across this and thought "How much could I get away with if I had one of these?"
Well, for starters, if I had one I would probably die.
That would be because I would use it & ride with the mentality that I was invincible & above the law, which I would be, if I had one.
What would you do?
Pretty damn good mod
- King Nicholas
- King Nicholas
Re: Pretty damn good mod
This one isn't quite as good but gets points for effort.
http://www.youtube.com/watch?v=MQSDLySi ... re=related
- photomike666
Forget the fine, both of these may get the book thrown at you.
- Team Monster
I was following a guy on a cruiser a while ago and as he went thru a red light in front of me reached behind and turned his rego holder 180o,Which was bolted to one of the lower corners of his number plate......Simple but effective
DISCO wrote:I was following a guy on a cruiser a while ago and as he went thru a red light in front of me reached behind and turned his rego holder 180o,Which was bolted to one of the lower corners of his number plate......Simple but effective
if i remember correct, i think Hoffy told me about it.
saw a copper at a guys bike, bending the rego label back and forth until it snapped of, then stuck in on the guys seat and walked off.
i had me Z one mounted similar, got a breatho on the odl road one day and he told me i had the label the wrong way and needed to be under the plate.
