I now understand that there is a well known problem with the older GPX models (mine is a 1991) when the rubbers wear out on the inside of the fairing.
Namely putting the bolt/screw into the inner liner of the petrol tank and creating your own custom designed fuel leak.
I know now as I have such a leak. Have a few ideas on how to remedy this. Temporary remedy seems to be holding up OK.
But time will win eventually.
Was wondering if anyone out there has had this problem and found a permanent fix. Just for the record buying a new tank is not a fix.
Any and all help greatly appreciated.
