After Cinishing a few jobs on the ZXR I got it to run off the battery and got the idle sitting OK but after giving it a few blips then a while more idling I turned it off at the key, turned away to grab something and the battery blew!
Nearly shit my pants to be honest!
Looks like 3 or 4 cells have given up and the battery was really warm afterwards and stayed warm for over an hour!  Got a replacement battery but am wondering if it could be the regulator that's given up and is over charging the battery?
Is there any way to test it before I put in the new battery or is it worth just replacing the regulator?
Other than the obvious issue it was a good day as the engine ran without smoking heavily and only have a small ticking to trace but that could be because I've taken the smog valve off and have simply connected the hoses together! Saw it done like that on another ZXR!
							Battery's shit itself!
Road, Sky, Road, Sky, Road.....  Ambulance
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
- Blurr
Seems to be the weekend for batteries to fails. That's 3 this weekend that I know about
Re: Battery's shit itself!
Any advice?
 - Team Monster
Yep and mine failed in the weirdest wayBlurr wrote:Seems to be the weekend for batteries to fails. That's 3 this weekend that I know about
						- Blurr
Only thing I can think of is using a multi meter.
Watch the charge in the battery drop on starting then watch the rectifier reinstate the charge slowly. If it spikes or overcharges then you could have an issue
Could it be caused by a connector block being used on the wiring in place of the original connector?  Found that today!
- TONY-J
 - Bike: ZX14R
+1 for battery giving up over the weekend.
							84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
						84 GPZ900r
91 ZZR1100
06 ZX14
