Rain sucks!
- Aussie Ninja
Rain sucks!
After a lot of screwing around I finally got a 4 degree timing advancer for my '98 6R. I wacked it in, fired her up and I could tell the difference just by the way she started from cold. She sounds tougher at idle if that makes any sense. Can't wait to test ride her. Only problem is its been raining for the last two days.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
I think its on the way Colette. Bugger it all. I have been off the bike for nearly 5 weeks and I am finally able to go for a ride and it starts to rain.Colette wrote:Send some here, we need it!
Hey Aussie Ninja, do you have pics or anymore info on this timing advancer? Sounds like the rain has given you some spare time
The Doc says my blood is green. Thankfully, there is nothing he can do to help
05 ZX6R Green Roadie
95 ZX6R Red Trackie
95 ZX6R Red Trackie
- Aussie Ninja
I got it from starcycle.com. It cost me $94. There is a couple available for your F. The part no. for 4 degrees is RTR-KAW-31-04 or for a bit more you can get an adjustable one and the part no. for that is RTR-ADJ-KAW-31. They look like the std ignition plate but when you put it in you can see it sits slightly more advanced than the original. They are made by factory pro. Check out factorypro.com.samhasa636 wrote:Hey Aussie Ninja, do you have pics or anymore info on this timing advancer? Sounds like the rain has given you some spare time
1998 ZX6R R.I.P.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
Hey thanks mate. I checked out the factorypro site and I am thinking I need to get myself one of those Gearbox star kits. The 95 gearbox is so stiff it is nearly impossible to clutchless shift. I wasn't sure what I was going to do about it, but now I know.Aussie Ninja wrote: I got it from starcycle.com. It cost me $94. There is a couple available for your F. The part no. for 4 degrees is RTR-KAW-31-04 or for a bit more you can get an adjustable one and the part no. for that is RTR-ADJ-KAW-31. They look like the std ignition plate but when you put it in you can see it sits slightly more advanced than the original. They are made by factory pro. Check out factorypro.com.
95 ZX6R Red Trackie
95 ZX6R Red Trackie
- Aussie Ninja
try changing your clutch fluid!samhasa636 wrote:The 95 gearbox is so stiff it is nearly impossible to clutchless shift. I wasn't sure what I was going to do about it, but now I know.
I was amazed at the difference it made to my 95... both the clutch and shift lever require much less force, and clutchless shifts are nice and smooth too
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
um how does changing the clutch fluid afect a cable clutch???Androo wrote:try changing your clutch fluid!samhasa636 wrote:The 95 gearbox is so stiff it is nearly impossible to clutchless shift. I wasn't sure what I was going to do about it, but now I know.
also if ur not USING the clutch, how does the fluid come into play...
could b wrong here, but the new zx6r is a cable clutch isnt it?? the zx7r is one of the few fluid clutch bikes...other than tourers...
I do apologize, my 95 zx-9r has a hydraulic clutch so I just assumedneka79 wrote:um how does changing the clutch fluid afect a cable clutch???
it changed the feel of the shifter, dont ask me why
Sure is but I think Sam is talking about his '95 zx6...neka79 wrote:could b wrong here, but the new zx6r is a cable clutch isnt it?
1992 Kawasaki KR-1S and 1992 Kawasaki KR-1S - It lives again, no wait it's died again...
2005 Kawasaki ZX-6R Green - ~20000ks, 5 rears, 4 fronts...
2008 Honda CRF450X Supermoto - Can I borrow some fuel?
2012 Honda CBR1000RR - !!!!!!!!!!!!!!!!
