Hi All,
Have a big problem with the zx9, it is blowing fuses (going through like 8 a day).
It happens at random times, Sometimes it will go 30 minutes but others only 5 minutes. It happens at low revs, high revs or just sitting at a set of traffic lights.
So I have tried to replace the headlight globe thinking that might be the issue, But nope still having the same problem.
Someone said that the headlight relay might be stuffed, But I cant see to find it anywhere (Have not removed the front fairings yet, Just the tank and rear fairing).
So i know there is a power serge somewhere, But just wondering where I should start looking
98 zx9 Headlight blowing fuse's
- State: ACT
Its not cold in Canberra, Your just a GIRL!!!!
- z900/zx9
Re: 98 zx9 Headlight blowing fuse's
Probably not much help but when I was always blowing headlight globes it was the actual plug that was the problem.
- fireyrob
Check for corroded parts. Yep the plug would be a good place to start
- z900/zx9
Yep nothing like a corroded plug said the school girl and the Homo.fireyrob wrote:Check for corroded parts. Yep the plug would be a good place to start
