SBK ZX10R triple?
- Kermit
SBK ZX10R triple?
Have been re-watching a few syke's & Melandri previous races and I noticed that the bike sounds different in the bends like its dropped a cylinder.
Looking into it I've come across that both SBK BMW & ZX10R have adopted dropping a cylinder in the bends.
So if this true, why drop a cylinder for bends?
Possibles
Curtail power?
Triple configuration like torque to power out?
Possibles
Curtail power?
- fireyrob
Re: SBK ZX10R triple?
The computer is reading how much available traction there is a couple of hundred times a second or thereabouts. When it detects slip (ie when the bike is leaned theres less tyre contact) it can retard the power by effectively shutting down a cylinder. Im not sure if it can do 2 cylinders?
Watch their hands, its off brakes and then throttle pretty much nailed full on. As the bike picks up it sounds awesome as it picks up the cylinder. How many highsides you see on these? The downside I guess is watching and listening to others using it as Im punting the 6 trying to get past
- MAXUMIS
Its for traction control , that's why they sound like there running on 2/3 cylinders under full throttle into curton situations . Kawa works on missing individual cylinders and bm's work on the total cut out mode(meaning it cuts all cylinders) for traction or anti wheelstand mode.
life starts at 200 kph!
Stand on the side of the track when a zx10r is trying to wheelie over the hill at EC. It makes a noise like its dropping a cylinder.
It's the easiest way to let traction control kick in without electronic throttle boddies and stuff.
What does your zx6 do when TC kicks in? Should sound the same in theory.
- MAXUMIS
Went out to the last ASB series at EC and was standing at the crest of the hill , herd all the 10's doing it(others with a different sound) but never heard one 600 do it ? maybe it does not need it under the same situation as the 10's with pro riders using there bike to there full extreme ? Saying that the 10 has around 30% increase (if not more)in power with a very similar ratio in geometry .
The 600's racing don't have it.
Only the 636 which can't be raced in the 600 class
- MAXUMIS
Thanks for the inputWattie wrote:The 600's racing don't have it.
Is the 636 that much quicker?
Yeah a bit if mid range.MAXUMIS wrote:Thanks for the inputWattie wrote:The 600's racing don't have it.
Same top end but I think?
- MAXUMIS
+1 setup for the average guy (meaning all the normal people with a bit of weight)out to have a bit of fun ..Wattie wrote:Yeah a bit if mid range.MAXUMIS wrote:Thanks for the inputWattie wrote:The 600's racing don't have it.
- Kermit
TC 2 or lower with full power in the dry I find its too intrusive in the mid range, when TC kicks in; the bike looses power like timing has been retarded.
Hmmmm next time you are out wilbo way we'll have to check it out
Suzuki don't have TC but?
- MAXUMIS
I think they have a timing system on them , meaning its capable of controlling the bike under/needed timing retart (the same situations)as needed . I am not saying anything about them But they do have a retart system far from kawa's system ..Wattie wrote:Suzuki don't have TC but?
