simple chain question
Is there anyway to get rid of tight spots in your chain?????
theyre only noticable when Im pushing the bike backwards....
New chain and sprockets usually but if it has a split link in it you could try pulling it off and giving it a wash in some kero and bending the links till it frees up.
Do you know how they are constructed? oring chains have orings to keep the grease in between the links when they make them so if the orings are worn and all the grease has died in the links theres a good chance the chain is past its use by date, the lube you spray on is to keep the orings moist and to keep things moving on the outside but oring chains also have lube on the inside.
Also if the sprockets are really pointy or hooked over one way you should replace them...well actually if you are replacing a chain you do sprockets as well and its all good for another 30000km with a bit of spray and adjustment.
- Nanna10r
- Team Ninja
Re: simple chain question
You've got 3 options Dj ....Dj wrote:Is there anyway to get rid of tight spots in your chain?????
a) Dont push it backwards
b) Replace it with a Newie
c) Buy a New Bike.
Isn't great to have choices
Cheers Brett
- Nanna10r
- Team Ninja
by the way the Best way to put Hot spots in a chain is to overtighten it Which stretches it at that point. Monos work on the same principal.
hth.
Cheers Brett
hth.
Cheers Brett
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
fark off..wot would u kno about monos?? when ur tall enuf to see over the screen without a booster seat then u can have an opinion...Pontikat wrote:by the way the Best way to put Hot spots in a chain is to overtighten it Which stretches it at that point. Monos work on the same principal.
hth.
Cheers Brett
- Nanna10r
- Team Ninja
I've overtightened a couple "Narfie" ya rabbit.neka79 wrote:fark off..wot would u kno about monos?? when ur tall enuf to see over the screen without a booster seat then u can have an opinion...Pontikat wrote:by the way the Best way to put Hot spots in a chain is to overtighten it Which stretches it at that point. Monos work on the same principal.
hth.
Cheers Brett
Just cause i cant crack a mono doesn't mean that "tiggr" doesn't with me hanging on.
Note the hanging on bit mate, maybe thats where you're going wrong, Handle bars are just like Drivers licenses mate the key is too keep a firm grasp at all times.
There's a tool joke or seven in there but we dont need to go there do we ?.
"Five foot fuk all racing".
- Neka79
- Bike: Z900
Pontikat wrote:I've overtightened a couple "Narfie" ya rabbit.neka79 wrote:fark off..wot would u kno about monos?? when ur tall enuf to see over the screen without a booster seat then u can have an opinion...Pontikat wrote:by the way the Best way to put Hot spots in a chain is to overtighten it Which stretches it at that point. Monos work on the same principal.
hth.
Cheers Brett
Note the hanging on bit mate, maybe thats where you're going wrong, Handle bars are just like Drivers licenses mate the key is too keep a firm grasp at all times.(touch wood)
hahahha thats a nice reply ya lil smarty ass....
as for team "5ftFA" can i join??
- Nanna10r
- Team Ninja
Nath I had you down as "Designated Drinker " in Charge of "Public Relations Female sector" of 5ftfukall.
Your still holding your end up aren't ya ?.
Cheers Brett
As for the chain wear drama mate wear earplugs mate & give it a flogging till it dies.
Cheers Brett
- Neka79
- Bike: Z900
oh u kno me too well .....Pontikat wrote:Nath I had you down as "Designated Drinker " in Charge of "Public Relations Female sector" of 5ftfukall.
Cheers Brett
