Post your results from the dyno.
Darwin
Re: Post your results from the dyno.
Post by Darwin »
191.9 hp 155.4 n.M.
I have it booked in at Flywheels on the 3rd. It will be interesting to see the result after a tune up.
kawaden
Post by kawaden »
04 Z1000 full akro exhaust, pcIII with custom map, bmc air filter with air box lid removed yada yada
if it doesn't have a MOTOR, it's not a SPORT.
I am surprised the Zeddy pulld more power than a ZX9 .. sorted 8)
SoundGuy
Post by SoundGuy »
176.1 hp - 116.4 m.N.
kawaden wrote:04 Z1000 full akro exhaust, pcIII with custom map, bmc air filter with air box lid removed yada yada
sweet....
ive got cans.. havent done the air box mod yet, as i havent got the bmc filter or pc3....
that will all be done together... and as soon as i sort this BS with the ex... mwahahahaha
Mel
Post by Mel »
My '03 636 got 117.2 hp at 13214rpm, 66.4m.N at 10842rpm.
:D
2010 ZX6R
1997 ZX7R
I ride like a girl...
Yes I think some of the figures look a bit odd..
In particular Glens and Watties, Gixxer Daves looked a bit low.
The z1000 was pretty high compared to the 9's too..
Compared to our previous dyno day the comparatve numbers are quite different.
Heres some other reference
http://www.sportrider.com/tech/146_weig ... l#kawasaki
My 10 - 180 and 126m.n
750 - 131 and 77m.n
To give an example at our last dyno day we had
3 x 04/05 zx10rs all with 153 to 155 rwhp
07 zx10r - 161 hp
Z1000 - 123 hp
98 ZX9r (with 110,000ks) - 131hp
zxr750r - 112 hp
had my 10 on the same dyno a month back - 168 hp
MadKaw wrote:98 ZX9r (with 110,000ks) - 130hp ?
131 dave.......
kawaden
Post by kawaden »
when i had the Z maped at doin bikes several years ago it made 128.6 hp and 93.5 nm at the wheel. on this dyno the figures were 150.1hp and 106.2 nm at the crank. given losses of 10 to 15% from crank to wheel the figures compare well. also both dynos show peak turque and power at the same point and the shape of the curves are the same. based on all this i think the results are about right.
kawaden wrote:when i had the Z maped at doin bikes several years ago it made 128.6 hp and 93.5 nm at the wheel. on this dyno the figures were 150.1hp and 106.2 nm at the crank. given losses of 10 to 15% from crank to wheel the figures compare well. also both dynos show peak turque and power at the same point and the shape of the curves are the same. based on all this i think the results are about right.
I'm not questioning your figures Its the comparative figures to the 9's that looked odd..
If 150hp = 128 at the rear wheel (which sounds about right).
that would mean the zx9rs would then be 148 hp = 126 rwhp.. Which is a bit low for 02 / 03's with slip ons.. not a huge amount though.
Using the same conversion, Watties zx10r would be putting out 142 rwhp and Gixxerdaves K6 with full system and PC3 would be about 144hp. Glens zx10 (the same as Watties) 149 hp.. all a bit low to any other RWHP dyno.
The last dyno Day Watties had more HP than Glens, now Glens has 7 more (same models same mods), the 06/07 also had 5 to 6 more than the 04/05, this one had em the same as Glens 04/05.. :shock:
The 12's should be about the same as the 10's but were much higher..
It looked like the bikes on early read higher than the ones on later.. :?
BTW, my 98 zx9r put out about 142 on the doin bikes dyno.. and it was running crap...
anyway, it was all good fun and great day..
kawaden
Post by kawaden »
i see what you mean, maybe the opperator was having an off day.
James
Post by James »
I was surprised that my 2000 ZX12 with a full Yoshi system, K&Ns & PCIII achieved less than 2hp more that Hoffy's ZX12 which is stock except for a cut-down slip on! (184.9 Vs 183) Im glad I bought my bike with all the mods - I'd hate to spend $2500 for a 2hp increase! :shock:
JetPilot
Post by JetPilot »
hoffy wrote:I am surprised the Zeddy pulld more power than a ZX9 .. sorted 8)
Must be the fuel injection. ;)
Kawasaki Z1000r 2012
Poyda
Post by Poyda »
Crappy looking 96 ZX6R With Akra 4-1, probably some jet work and a stock filter :?
108.1hp @ 12903rpm 66.9N.m @ 10078rpm
Pete
The (no longer) ugly 96 ZX6R
gixxerdave
Post by gixxerdave »
Wattie wrote: gixxerdave got like 165 or something on kis k6 gixxer with a full system and pc3 :?
169 horses actually.. and 112nm of torque.. PC3 with a micron map, K&N, pipe... and the valves are overdue for checking.
engine mod time here i come. (bugger the cams) 8)
