Jen
Yeah... but I've had plenty of good starts, time and time again! I'm going for a good finish this timeJennysc wrote:Hmmm, only 1/2kg this week, haven't quite got the right mindset yet. 2kg Cath, that's a good start
Jen
Putting weight on is easy. Just eat big (the right things of course) and train big. The problem is it takes a while so it seems you are not progressing at all, ie if you can gain 1 kg a month you are doing well. Go by the weights you can lift and if that is progressing the size will follow. I've never trained anyone who hasn't been able to get bigger and stronger.kevindinho wrote:man loosing weight is easy, its hard to gain!!! im tryna bulk up for the last 6months and still not much to show for.
Gaining weight is easy - eat plenty of protien, plenty of carbs, keep the reps low and the weights high. Getting good power to weight ratio, that's hard. In BMX racing we aim to bench press our body weight, curl half our body weight and squat double or weight. I need to be lighter and maintain strength (less fat would also help).Nelso wrote:Putting weight on is easy. Just eat big (the right things of course) and train big. The problem is it takes a while so it seems you are not progressing at all, ie if you can gain 1 kg a month you are doing well. Go by the weights you can lift and if that is progressing the size will follow. I've never trained anyone who hasn't been able to get bigger and stronger.kevindinho wrote:man loosing weight is easy, its hard to gain!!! im tryna bulk up for the last 6months and still not much to show for.
