05 ZX6R full service cost?
Re: 05 ZX6R full service cost?
I did at least 3 last year Dave..... you & Kev were on the list
- Six Addict
- Pinchy
- Bike: Ducati
rob's done mine before, I got the 3D how to guidezxsixr03 wrote:You've got the rear stand, why pay someone else $70- $80 per hour, do it yourself its pretty easy job, there's even a how to on here by Robracer.Six Addict wrote:im also getting new chain and sprockets, which will add to the cost
Once mastered makes it cheaper also to drop off just the rim for a new tyre too.....
- Six Addict
- Pinchy
- Bike: Ducati
We did but I've been a bit of a bad boy... I ended up with a very bad tight spot, and there is no room left for adjustment anywayrobracer wrote:I did at least 3 last year Dave..... you & Kev were on the list
but I figure I did 5 track days and about 20,000kms in the past 12 months... so it's not too bad, but I'll be aiming for better next time
- Six Addict
- Pinchy
- Bike: Ducati
mate, its all in the works already... but thanks all the same
- kevindinho
Ahh rob great lesson buddy!
no worries Kev
Bike goes in tomorrow & will be ready early next week
OK that was not too bad.......
I told the mechanic to only do the clearances Plugs air filtes & sync the injectors, basically everything under the tank & that I would do everything else.
The total cost was $572 & that included all the valves needing re shimming...... best bit is they are not due for another 24,000 K's.
Add to the cost the oil & oil filter that i am doing tomorrow & the cost is not too shabby.
Hey Rob,
Were the gaps to wide or had they closed up?
Gen 1 ZX10 puts the saki in Kawasaki
I will ask tomorroz when I pick up
- Six Addict
- Pinchy
- Bike: Ducati
my valves didnt need any adjustment, athough my rocker cover gasket needed replacing, and everything needed a good clean out of dust... seems the air filter wasnt doing its job... had the carbies stripped and cleaned too
I recently did the 36,000 Km service on my 04-05 Ninja thou. Same deal... All the clearances were within spec.
Normaly the valve clearances close up as the valve/seats wear.... "Valve seat Recession".
Having said that; clearances can, and do open up, but it is not as common.
All were closed & needed shimming. bike sounds quieter now & everything else has been done on my end so she is ready to go
Ohhhh & lube your clutch cable...... it feels soooo goood
Is that what they're calling it these days???robracer wrote:Ohhhh & lube your clutch cable...
Tony
I have become race...
