FI light on??
greaser07
Re: FI light on??
so how do ya know if the servo motor is gone?it still rotates when the ignition is switched on...also if i just plug in a servo buddy will this cure the prob??
FI light on??
If the servo doesn't Reach a limit it can set a code off.
Robracer explained to me how to do it in Red Daves old 6. I put a flat length of alloy about 10cm long and put it onto the top of the servo, then when it spun it hit the subframe and stopped, then went back the other way till the other end hut the subframe and all was good.
Maybe rob can take a pic if he still has the same setup on his bike?
Re: FI light on??
Yep just checked & my one is farked, not moving at all....... will have to get a servo buddy now
Here is the current set up:
- IMG_0684.jpg (154.36 KiB) Viewed 5996 times
Re: FI light on??
oh, not the subframe, just the plastic block.
- Jonno
- Mobile Chicane
Re: FI light on??
Servo buddy is about $100?
Re: FI light on??
C'mon Wasabi now is the time to step up
- seiko1
- Bike: ZX14R
Re: FI light on??
Funny how the mind worksWattie wrote:If the servo doesn't Reach a limit it can set a code off.
When I hit the HUT, I automatically switched to a kiwi accent
greaser07
Re: FI light on??
ive tried servo buddy but light is still on???ive tried to bring up the code but nothing happens(turn on key,keep reset button pressed in odo mode)????
greaser07
Re: FI light on??
now have FI light on when ignition is off only,ive got the exhaust butterfly permantly open as it wouldnt go past 5k in any gear otherwise,does this cause any issues?bike seems to be running ok,but light is pi-ssin me off,does anyone know how to check for FI code????
FI light on??
FI light is meant to flash when bike is off.greaser07 wrote:now have FI light on when ignition is off only,ive got the exhaust butterfly permantly open as it wouldnt go past 5k in any gear otherwise,does this cause any issues?bike seems to be running ok,but light is pi-ssin me off,does anyone know how to check for FI code????
greaser07
Re: FI light on??
aaaahhh!thats ok thanks,i never really noticed it flashing before!anyway does it matter if the exhaust butterfly valve is constantly open??Wattie wrote:FI light is meant to flash when bike is off.greaser07 wrote:now have FI light on when ignition is off only,ive got the exhaust butterfly permantly open as it wouldnt go past 5k in any gear otherwise,does this cause any issues?bike seems to be running ok,but light is pi-ssin me off,does anyone know how to check for FI code????
Re: FI light on??
you might loose a little back pressure down low and at smaller throttle openings, but no biggie.
