Braided Lines
Braided Lines
Does the other caliper also have two lines going to it like that or just one?
Re: Braided Lines
good question, just looked at a picture of it and it only has one. What are you thinking?
Re: Braided Lines
im looking at bikes online (bikesales.com.au) and some have 2 lines, others have one. least to say im
- born green
Re: Braided Lines
Without seeing it, who know's what's been done...myzx10r wrote:im looking at bikes online (bikesales.com.au) and some have 2 lines, others have one. least to say im
Original it shoud be one line from the M/C down to the right cailper, then a 2nd line from the right cailper over the gaurd to the left cailper..
But if ur changing to hell ect, it wont matter, just get the (race) pattern lines... two lines from the M/C one to each cailper
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
Re: Braided Lines
so when i buy the hel lines, it will come with 2 braided lines. Do i need to specify "race pattern lines"
- born green
Re: Braided Lines
yep, prob, or u may end up with the 3 lines, as in same setup as oem.myzx10r wrote:so when i buy the hel lines, it will come with 2 braided lines. Do i need to specify "race pattern lines"
They should ask which setup u want.
The kit will come with all the bolts ect, The M/C will be a longer bolt to take both lines, easy to fit and a lot easier to bleed.
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
Braided Lines
I'm thinking it goes down to one side then loops over to the other caliper not the norm generally but I have seen it done before. Just order the hel lines and maybe in comments write that you want the two lines that go individually down to each caliper from the m/c.
Don't know where your located but deano at Dynoverks in boronia can order them in pretty cheaply if your worried about getting the wrong ones.
Re: Braided Lines
All sorted. there are 2 config. twin line or cross over..............i think ill run with twin line. Looking at Venhill braided lines from the US, but for price, i'll go with the Hel.
Any thoughts on my other issues regarding weathered (possible erosion) on the cast iron parts of the bike?
- born green
Re: Braided Lines
Venhill's are good, most BSB teams use them, but then prob because there english.myzx10r wrote:All sorted. there are 2 config. twin line or cross over..............i think ill run with twin line. Looking at Venhill braided lines from the US, but for price, i'll go with the Hel.
I fitted a set to my mates 08 zx10, he got them cheaper than the hells.
But the venhill's arnt a pressed end like hell, goodridge ect. there a flanged end, like a car.
The other issues, maybe the bikes been out in the weather for some time???
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
