Chain installation
SNR wrote:Is that with the back wheel off..........don't think the chain twists that much hit it on a flat surface. Can do that if you have the swing arm off!
mrmina wrote:mate on the chain pin there should be a mushroom end and a normal round end.
1. insert pin.
2. place mushroom end down on a hard surface.
3. Use a punch set to flat the other end. Note: not too rough
4. File the punched to make it look neat.
At a loss, please explain! :?
snr
place square piping behind it or something solid that wont move. Done it on a mate's gixxer. Use the back wheel as a backing.
Matt_'98ZX9R
Post by Matt_'98ZX9R »
Thanks guys seems theres a few different ideas on the chain but i've taken mine over about 100kms since i got the chain on the other day, ( hot and really clear here in tassie for a change :) the chain seems to be holding out fine the rivets look good, well alot like the other rivets which i reckon is pretty alright.
The grinding noise from the rear disc turned out to be the rear caliper grinding on the disc.. from now on the new rule is take a really good look before you hop on after home maintenance.
Anyway thanks again lots of help.. really just wanted to make sure it could be done before i tried.
Matt
