Dude, cheers for the offer. I spoke to a mate today and he told me to take it to his mate. It going to cost a case to installNick wrote:If you fancy a quick fang across the bridge one evening to Maroubra i'll be only to happy to help you.PM us if you need my address.
Rear Brakes
If you see me say hi, if you dont see me dont miss me.
Call me Dave - Just trying to fit in
				mattyv74
 - Team Kitty Litter
 - Bike: ZX7R
and no anti squeal shim???Smitty wrote:
cheers[/quote]
Just a smidge of white grease on the BACK of the pads does the job.
						- ty
 - Team Ninja
 - Bike: Honda
my 9, and I'm pretty sure the 6, has a holding pin at the back of the caliper that goes through holes in the back of the pads to hold em in place - the Rclip goes through a hole in the pin to hold IT in place.Smitty wrote:what bike's this for...???
never done a rear caliper with pins or an R clip on it
Dunno what an anti-squeal shim is.
ty
on my 95 zxr 750 it was very easy.
1. Take off plastic cover on bottom on caliper.
2. look under neith caliper. You should see the 2 pins that are holding the pads in as well as the split pins that hold these pins in.
3. Remove split pins.
4 Slid pins out through the hole on the outside of the calliper.
5. Pads should fall out.
To put new ones in pretty much the exact opposite. AFTER you push the piston back into the caliper a little
