double bubble???
Re: double bubble???
matchan wrote:
hidepenny wrote:what's double bubble screen>??????
A must for the 03/04 636
heres one which came from one of our sponsors (racersden.com)
..nice sticker on the screen :D
hidepenny
Post by hidepenny »
is it tinited too??
and the URL doesn't work :?
hidepenny
Post by hidepenny »
and sorry,,...if i 'm not too fuss about the double wobble nobble bubble,
can i take the original off and just tinit it?
Post by mick_dundee »
Ho, probably can and probably find it will cost more than a new screen if indeed it can be done, tinted screens are made from tinted perspex making it a one stage rather than 2 stage process.
matchan
Post by matchan »
is it tinited too??
No, it wasn't tinted, but they did do tinted and iridium screens.
powerbronze also do screens I think, they are a sponsor to.
You'll find with the tiny screen on these bikes that approaching 200kph (on the racetrack of course) you get buffetted around a lot by the wind, at least that was my experience.
Matt
chameleon
Post by chameleon »
http://www.msgroup.org/DISCUSS.asp
....As to 'aerodynamic', says who? Wind resistance is not just the angle at which you hit the wind. There is as much resistance caused by the vacuum behind your windscreen than from the wind hitting it in the front. The greater the 'apparent' surface area your windscreen has (the height times the width as seen from the front), the greater its resistance is, in one form or the other. And, lest you think that's not all that important, the faster you go and the larger your windscreen, the more weight you take off your front tire. There comes a point where there is not enough traction left (traction is a function of weight) that your steering becomes 'mushy' and 'slow'. Indeed, with enough speed and windscreen size your steering becomes IMPOSSIBLE as there is no longer any weight on the front tire at all!
hidepenny
Post by hidepenny »
it'll be another 10yrs or so before i even step my foot on a track :(
matchan wrote:.....You'll find with the tiny screen on these bikes that approaching 200kph (on the racetrack of course) you get buffetted around a lot by the wind, at least that was my experience.
Matt
a dubbub screen does not help
when you sit up at the end of the main straight at PI
....doing 240 :twisted:
ttc
Team Black
Post by ttc »
there's a pic of the double bubble on mine here..
http://www.ksrc-au.com/phpBB2/viewtopic ... highlight=
eagle screens in WA, will deliver overnight :D
nicely finished job, they're currently making me an aftermarket one for the z1000 :)
ZZRCHIKKY
Post by ZZRCHIKKY »
i have a standard tinded screen on my Zzr and it dosnt help the visability of the speedo and stuff but becuase that dobble bubble one is higher it might keep more sun out :)
mate tinting the screen wont do fark all except look cool...
i had one on my vtr, and on my blade...both double bubble
as stated they reduce wind noise when ur tucked in as they re-direct the wind over ur head, and give u more room to tuck in..at normal speed they deflect the wind from about chest height, to face height....
they do however make it easier to see the dials etc as they sit up higher so ur line of sight is changed.....
ZZRCHIKKY wrote:i have a standard tinded screen on my Zzr and it dosnt help the visability of the speedo and stuff but becuase that dobble bubble one is higher it might keep more sun out :)
unless u have ur head down under the screen, tinted doesnt help with shit....
ZZRCHIKKY
Post by ZZRCHIKKY »
Neka, i baisicaly just said that :P
Plaz
Post by Plaz »
wanna see ya dials better?....try this:
P2100002 (Small).JPG (25.93 KiB) Viewed 807 times
gearbox
Post by gearbox »
Hi Neka,I have had a ZZR600 and now a ZX9R ,would a double bubble help with [normal riding position] wind noise? I have a new Shoei and still lots of noise with both bikes,if the wind hits you around head height will it get louder or just buffet my head around? cheers GB :lol:
