Pa Kettle should be able to wring well over 200 out of the bimmer.....I think top-speed on one of those babies is 220-230 odd ??Neka79 wrote:interested to kno how much Strika's grandpa beemer will spend??
how fast does your bike go
200.....on a farking airstrip.....he'll be needing alot of road to do thatGosling1 wrote:Pa Kettle should be able to wring well over 200 out of the bimmer.....I think top-speed on one of those babies is 220-230 odd ??Neka79 wrote:interested to kno how much Strika's grandpa beemer will spend??
Good stretch of $2.75 on the way to supers this year..On the magic school bus.
hmm, I think you may be in for a bit of a surprise..........the old flat-twins aren't going to rip your arms out of their sockets under accelerationhoffy wrote:.....200.....on a farking airstrip.....he'll be needing alot of road to do that![]()
A good mate of me and PC's has an old R90/6, fitted with an R100 motor that has had plenty of modifications - this old girl is good for about 220 on a good day, and gives the Pearl a good run for her money
matchtheclown
99 gix 600 it was sproketed down alot, 220 down the straight A EC that was after putting on a speedo healer because it was out alot obviously.
06 zx10 - only done 1 track day on it. But it shows about 263 at redline in 5th which is what I was hitting @ the end of the straight if I had more stick i'm sure I could have been getting into 6th.... But I was enjoying my bike in 1 piece.
- Nanna10r
- Team Ninja
Every horse with a fuggen ESH in it'shname Whataya reckon Tappy "SHOUNDS like a Bit of a Shet Up ?"Rumbles wrote:my 05 ZX12R has 300 on the clock and ive had it there plenty of times got tankcam of me holding it at 300
- mmamster
Last Monday at PI I hit 235 km/h at the braking point on the main straight before chickening out, on an 07 GSXR600. It will go faster if I have the coochies to brake a bit later or enter the straight with some more corner speed...
Mark
CBR1000RR 2009 roadie, ZX10R 2008 track
GSXR600 K7 road sold 12/09 (as a wreck)
GSXR600K7 racebike sold 10/11
ZZR 250 sold 2/2007
ZZR 250 sold 2/2007
- TITANIUMBULLET
the cops alledgedly seen me do 200+ but i have personally done 280 on enclosed private road on private property on an r1 back in 98.
the 05 zx1or hasn`t seen past 260kph,stock bike, i reckon with a bit of work 300 should be easy!
2019 multi 1260 ENDUROTOURER
1972 H2 750 BLUE PRIZED POSSESION THE KING!
1974 H1E GREEN CLASSIC
3 X 72 s2 350 ALL RED
1 X 73 S2 350 BLUE
08 ZX10R WEAPON SOLD08
klx450r bush basher(sold)
05 zx10r titanium(gone)
2 X 06 ZX10r (gone)
07 zx10r track bike(gone)
06 r6 yammy track bike(gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
Buck
I suggest the second method mmamster. Get that last lefthander fastmmamster wrote:Last Monday at PI I hit 235 km/h at the braking point on the main straight before chickening out, on an 07 GSXR600. It will go faster if I have the coochies to brake a bit later or enter the straight with some more corner speed...
stay off the ripple strip as you exit and get down behind the screen.
try reading some porn instead of the stocks n shares prior your session
steve
- mmamster broadford.jpg (209.94 KiB) Viewed 1855 times
The dealer BSed you Blue, I have had the 05 12 off the clock, so have others, thats Busa's that are limited.Blue14 wrote:Well on my zx12r which is an 05 model, at 297 the speed limiter cuts in, so ive been told by the dealer. Cause i can give you the mail, i aint tryin it !!
Mind you it had PCIII, Microns full sys etc. but the ignition was still the same.
Speedo goes to 280 plus two notches to 300 and then about a 20k gap to the stop, it was on the stop but NO WAY was it doing 320 (200mph).
I have reada lot of 200mph club stuff, so understand just how hard it is to get from 310 to 320kph.
I had a different front sprocket and the speedo wouldnt be accurate anyway.
ZX7R (modded) 280k on speedo, i am guessing 260-270 in reality
81 SD900 Darmah and the MIGHTY NSR150SP both 190k
How cares anyway, it is just HP, there is no skill involved
