Z1000 Fork Upgrade Complete
Re: Z1000 Fork Upgrade Complete
Chitchats wrote:
Phil wrote:Did you upgrade the springs and re-valve? Looks fantastic :kuda:
I'd suggest wacking a cable tie around the lower fork to see how much travel you are using ;)
Tell me gents, what sort of travel should the shocks have?
Mine on my commute (no real "hard" braking) i had 70mm of travel.
Fork upgrade done by previous owner. 8)
Thats a hard question to answer. My forks were shortend a little, that comes from the allowable travel. So I will not have as much available travel as others. The better question is "how far off the bottom is my cable tie" ;) My answer for that is about 4-5mm, ie just off the bottom. I am still working on the forks with the higher rear tyre ;)
Damon Z1000
Post by Damon Z1000 »
I get about 10mm clear of the bottom with 1kg springs and a fat bastard on the bars
Team Crash 2010 Ooooops
Mattjin
Post by Mattjin »
The specs I remember reading on the ZX6 forks were 120mm of travel. Static and rider sag chew up a chunk of that.
Chitchats
Post by Chitchats »
Damon Z1000 wrote:I get about 10mm clear of the bottom with 1kg springs and a fat bastard on the bars
Ive got about 20mm, might ride to work in a rush tomorrow to check clearance under heavier braking. :twisted: ;)
Chitchats
Post by Chitchats »
Ok,
Update
Pretty much use the lot.
Went to a day at Wackyfield Park on Wednesday, made some further adjustment to the forks over the day.
I'm going to see how it goes on the road now, doubt I'd ever use the brakes on the road as hard as I was at the track - especially after doing a pillion lap with Mr Giles last Friday at Phillip Island..........I have obviously got ALOT to learn in regards to braking :shock: :shock:
BTW, big thanks to Keith Muir for the photo ;)
Bastard!!!
