Indicator Switch Thingy
- tape
- Team Ninja
Question to all you that will obviously know more than me.... not hard.
Is there a way to change a manual indicator switch off an older bike to the press off type? thats all the technical speak in my vocab after several Jimmy's...
icebreaker
- Administrator
- State: Tasmania
re: Indicator Switch Thingy
I'd imagine you just replace the hole unit on the LHS Handle bar..
Then it's just down to wiring it back up again.
But I could be wrong.
Ducati Monster S2R1000
- Quarkz
You could yank out the switch and just superglue a button in there and reatach wires until it looks like it might work.
But, I am wrong so, don't do that.
Kylie
2013 Kawasaki ZX636 / 2004 Kawasaki ZX636 / 1999 Aprilia RS250
- ty
- Team Ninja
- Bike: Honda
Agree with Dan - you should be able to find a switch block with a push off and just rewire it up.
ty
ty
- mfzx6r
Dans pretty right I'd say.
The auto cancel type thingy is all in the switch.
mario
mario
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
'01 zx6r
klx300r
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
id go with quarkz..but then again i AM dodgy...
- mike-s
its honestly impossible to say on the size thing without seeing both the switches opened up, but i'd guess that the size of the push-cancel one would be a bit bigger, simply as there's a bit more "mechanical" stuff going on.
Find out the diameter of your handlebars and width of your switchblock and try and locate a switchblock with the required facilities that fits yours.
last switchblock i bought cost me about $40 from a wrecker
(i put a late 70's rhs switchblock on a '71 cb250, i then had a killswitch that worked
- Neka79
- Bike: Z900
u may even need to get different clip ons?? depending on how much space, and wot kinda diameter u have to work with??maybe one of these nerds with web links can help?? then wen uve done ur research, off to the wreckers...
can u fix it with bubble gum or duct tape?? im good & handy with the duct tape!!
as long as the wiring from the old unit matches the wiring of the new unit u should be able to do a direct swap or u might have to get a multimeter and see what wires go where.
