Hub Bearings, Seals, etc.
tape
Post by tape »
Where to get seals and hub bearings from? I was wondering whether normal bearing retailers sell hub bearings and seals? Can anyone point me in the right direction.
Preferably not a Kwaka dealer though please.
Mick :drinkers:
http://www.insptag.com.au
Pull the bearing out, and get the code off it. then jump on here and order it!
http://www.industrialbearingsupplies.co ... asp?ID=180
Nachi make stuff for bikes, and a lot of the bearings are common size. :)
Or locally in Maidstone here.......http://www.conbear.com/
bought gpx750 front wheel bearings for $7.50 per-side from the parts counter at sysney cit cycles, definately was a bit surprised as i was expecting 15-30/side.
Strika wrote:Pull the bearing out, and get the code off it. then jump on here and order it!
as Strika sez
or try RBC or CBC bearing stores
balanse
Post by balanse »
I use the local CBC and the guy takes one look at the old bearing and goes and gets the right size I need.
Sometimes the part is OEM unique and they can't do, but they have it more than not.
