GPX 250 float needles + Carb screw settings
Hey guys i have the supplement for the gpx 250, yet cant see factory screw settings for the carbies? Anyone got good suggestions?
Also how much should float needles cost me for a pair (disassemblin carbs in a few hrs)
ok anyways after no messages i realise it was a kind of stupid question about needle settings, given there are no screws to adjust it (from what i can see).
My float needles were fine too. Just gave it a clean up, and she runs better.
However when the bike warms up a bit (needle above cold on temp gauge) it idles near 1500, then drops to 1000, then stalls...
I havent balanced my carbs yet, but can any one suggest what would cause it to cut out. If i dont sit there jabbing at the throttle (revving it to bout 3000) then it eventually stalls. What is it?
Someone Please?!
Someone Please?!
- mike-s
if its not a synch issue, either 1) your float levels are out or 2) your idle jet setting is wrong on one of the carbies.
I'd suggest try resetting your idle jet setting to 2.5 turns out (i believe that's the standard setting), increasing it to three turns out if you've got an aftermarket pipe on it.
Also it'd pay to ensure the float levels are the same as that affects the 1/32-1/4 throttle opening, which is most often used when cruising around.
i havent got the base manual so cant tell you where the screws are , they are going to either be on the side of the carb or underneath
I found this useful guide
http://ninja250.kingston.net/~jeb/Kawasaki Ninja 250 FAQ.pdf
but it doesnt mention the screws
either way
do not unscrew your main jets
you need to find the screw
settings
mix screw is 1 3/4 turns out
float height is 17mm +/- 2 mm
if you bike has a fair few kays on it they do get bad hot idle due to excessive engine gas blowby being pumped back into the airbox via the crankcase breather
solution is to remove the hose from the airbox and put a little filter in it and possibly into a catch can as it can blow some oil out of this hole
block off the hole in the airbox and now your engine will thank you by not having hot oily air pumped into it
either way
settings
- mike-s
r.e. the idle jets, they are usually on the underside of the carby, on the part that connects to the rubber manifold that bolts to the head of the bike. I still think you should check that, if thats set up correctly then you shouldnt have any trouble with the warmer air from the venting tube.
If you still want to follow the its-the-vent-pharking-it-up avenue, try a inline air filter as suggested above, but for environmental friendliness and stopping it leaking shit onyour bike and the road may i suggest you have it venting into a film canister with 4x 2mm airholes on the top on the sides (drill a hole in the lid in the centre and epoxy in from both sides a 3/32-1/4 inch tube that you connect to the re-used fuel filter, you'll just have to remember to empty it once a month or so.
