I need a Good mechanic?
- Zamo
Hey,
is there anyone here from around the western burbz of sydney that knows of any good mechanics? just for services and things like that.I used to use a guy in st marys but he shut down not so long ago,since then ive been gettin help off my mates but thier skills are limited. and i want to start modding my zx6.
- Glen
Mick at Castle Hill Motorcycles does good stuff. Victoria Ave Castle Hill just across from Heartland Holden in one of the industrial units.
If he gives you a time frame for stuff add a bit on though, the man don't rush but he's good and fairly priced.
- Zamo
Geply to glen
Thanks ill try n check it out.
I-K
Fitting a slip-on to a (presumably, going by your av) 636-B requires that a grand total of two fasteners be undone; the muffler bracket nut on the right pillion peg bracket and the bolt on the constricting clamp which secures the link pipe to the collector.zam001 wrote:the main one i want to do is an exhaust system just to open it up a bit.
Fitting a full system requires that you get at the header nuts on the front of the cylinder head. Slightly more difficult, but still in the "laughably simple" category.
I'm curious... why would you think you'd need to take the bike to shop just to get a race exhaust fitted?
- Zamo
I-K wrote:Fitting a slip-on to a (presumably, going by your av) 636-B requires that a grand total of two fasteners be undone; the muffler bracket nut on the right pillion peg bracket and the bolt on the constricting clamp which secures the link pipe to the collector.zam001 wrote:the main one i want to do is an exhaust system just to open it up a bit.
im still pretty new to everything so im not really that confident yet,but if its as easy as you say ill definately give it a crack.
!Thanx for yor help!
- mike-s
handy hint, just make sure you get both a manual for your bike (worthwhile in the longer term) and also get a new set of crush washers for the exhaust ports for fitting a new exhaust.
Newer bikes seem a lot easier to fit systems on, my old bike was a right cow of a thing, oil cooler and radiator had to be removed, and copious quantities of arsing about to do what should be a simple job. From what i've seen newer bikes are simpler, if only by the fact that bike designers have kinda learnt what to d and not to do.
- Burky
Zam just as Mike said get a manual, the info in these is priceless you can allways look at what you need to do and any special tools you require for that job. Nothing worse than getting the thing half apart then finding you that you need a tool that does not resemble what you have in your collection and the Hammer can't fix. As for the exaust system change have a crack at it it is an easy change. Enjoy the fun of DIY (and beer on the Job
). It's all good.
- mohawk miss
- Bike: ZZR600
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
i did the half system on my vtr and changed it from a low set upo to a high rise...and i knew NOTHING abt bikes then (i kno little more now) and it only took me a few hours..and they have 2 pipes!!
mioke is right, if ur changing the full system, get them washers in advance or ull leak smoke everywhere ...there only a few bucks per set...
the only thing u may need a mechanic to do is dyno/tune it if so required, but ussually if ur gunna do that u'd do jets as well...
