Does anyone have any advice on how to tackle them, I just cant seem to get the hang of them
Damn Hairpins
- mohawk miss
- Bike: ZZR600
Damn Hairpins
but it fell off.
Pilot of the Aloominum Falcon
but it fell off.
- Nucci
Ok on my experience I would say that advice is just down right stupid..Colette wrote:I hate them as well - was chatting to someone about this recently and was told to take them in first gear and fan the clutch (I have always tried to take them in second gear and wondered why I struggled..)
First thing if you are struggling with a hairpin the last thing you want is twitchy power delivery, keeping the bike in second helps negate this, unless it really is bogging down in second in which case ok, shift it down to first. But unless I am doing a tight u-turn I would never be using the clutch to modulate drive to the rear wheel. In canberra we have ultra tight roundabouts in small suburban streets that you take at about 20kms an hour and you dont use the clutch to negotiate these.
A hairpin is like any other corner, you should have set up your speed before entering the corner, and like in most cases, slow in fast(er) out works well. Getting your entry speed, body position and line are the fundamentals for getting any corner right.
But as I originally said, practice makes perfect.
05 ZX-10R
nothing to see here....
- Blue14
- Bike: ZX14R
Incorrect target fixation is a big problem when cornering as we know. So you will find most of your problem could be your just not looking far enough through the corner. I had that problem in my early riding days. Hopefully you can sort your problem, but always remember, do it at your own pace.
- Nucci
Yep Blue12, and your body position and line are very important when determining how far through a corner you can see. As the hairpin in question from the OP is a left hander, you want to be towards the right of the lane but still keep a good buffer from the centre line.
But sometimes you just cant really see to far from a corner especially uphill/cresting tight corners! But looking as far through the corner as you can helps..
Hmm maybe I should have put all this in my first post.
05 ZX-10R
- mohawk miss
- Bike: ZZR600
Ha ha ha haI think someone found Springwood road...
The first hairpins I ever rode through was Galston Gorge, coming back from Road Warriors (as a Learner). It was in the middle of a thunderstorm, you couldn't see 3 ft in front of you, there was at least 2 inches of water sheeting across the road
Pleased to see its not just me,though.
but it fell off.
but it fell off.
- Glen
Lots of bike in, body out ie keep your body straight, the bike pushed down and your head turned. If it's really tight remember your slow riding from your license test, ie back brake, slip the clutch a little and keep the revs up.
Practise tight circles ie like your doing a U Turn
- Glen
Not necessarily so. If it's a really tight hairpin ie the 5k corners on Galston Gorge this is precisely what you should do. It's like a Uturn, slipping the clutch will help keep everything smooth and combined with some rear brake and a few revs will keep the bike fairly stable.Nucci wrote:Ok on my experience I would say that advice is just down right stupid..
It's all in the learners and P's course
