33 degree day
towing the GN250 and loaded with bike gear etc behind it @ 100km/h
hit 'reserve' which I'm guessing caused the leaness which killed it.
It spewed oil out everywhere- weirdly from the exhaust flange of #3 it seems. Musta not been sealing there very well. I used that cement-like gasket stuff for exhausts to seal the headers- all seemed to crumble. Next time silicone. Got freakin hot too.
It still managed to do another 60km like that and pulled 500kg (230kg GT, 120kg me and 180 or so GN and trailer) up the Toowoomba range which is a 10% grade.
I hope I haven't caused too much further damage. I did a compression test on the engine of my '83 wreck and it was all over the place. I don't want to pull apart a complete running bike (my '87) just to get an engine for the '86, so have decided to fix the current engine. Last night I pulled the '83 engine down and she has a beautiful set of pistons. So am going to use those and the barrells to get her going.
How do you tell if the pistons are oversize? They have no numbers on them. I'm guessing you measure them with callipers, which I'm not too good at. Gotta buy some new rings.
How do you measure the bores to see if they need boring? I hope they don't! Going to be an expensive fix otherwise.
The bit of the piston that blew out musta got jammed between piston and head- there is a witness mark on the outside of the piston- actually bent the top ring land down to hold the top ring tight. It has some small marks on the head, but the valves seem alright.
Would you worry about the marks in the head? How do you check the valves for bend? How do you seat or grind the valves? I guess I should since I'm in there. Would you be concerned about the bits of piston going through the engine and causing further damage? There is a little scoring on the camshaft bearings, but not too much. Thanks for any advice. Reckon this one is gonna keep me busy for a while. Rough guess on cost is $500. Last time I did rings, gaskets and o-rings for the topend cost me $430 but I broke two sets of rings assembling it. ($40 a throw.)
I started it up the next morning and it blew the oil sightglass 20 metres. Musta had some fuel leak into the sump. Hehehe!
