ZX9 Rubber
Weekendwarrior
ZX9 Rubber
Greetings,
I am checking out tyre prices around the traps, need a rear tyre.
Just wondering what brand and size people are using on the ZX9's.
The manual says 180/55-17 but looks like a 190 width would go in???
Regards,
JB
Regards,
JB
- Loz
I can tell you Dunlop Qualifiers are rubbish. They scallop very quickly on the front, and stand the bike up under brakes.
Mono rono @ Balls reckons the pirelli diablo corsa and supercorsa are the way to go, such a heavy bike needs the sideways stability of the pirelli's extra lateral steel belt... Or something.
Nekkid Niner.
- Strika
From personal experience the Metzler M3 180/55/17's are nice. Excellent road grip and good mileage. If you want for something a little stickier then the same brands Racetechs are nice tyre too. Better mileage than most road tyres but with racetrack grip. The M3's are a better wet weather option however! HTH
Loz wrote:I can tell you Dunlop Qualifiers are rubbish. They scallop very quickly on the front, and stand the bike up under brakes.....
Weekendwarrior
- Nanna10r
- Team Ninja
In 60 thou kms on my F model 9, best Value tyre was the Shinko stealth 003.
Grippiest was the Pilot Race follwed by the Racetech.
Most fun was the Pirelli Corser.
Quickest warming was the Bridgie 014.
Also Had a OEM Pilot Road, Bridgie 020, 002 (road version) & 012SS.
Lots of good choices out there, but unless your doing the Drags' i'd stay with a 180mm rear.
- Loz
This is something I have noticed coming from Supercorsas, which were great, to BT002s which were good but not as good as the Pirelli. The Qualifiers felt odd from the moment they went on. Just my experience. Suspension settings I'm running are very close to stock. Qualifiers seem to grip OK once they warm up, I just don't like the feeling they give. Next on will either be a set of Pilot Road CT2s for winter, or if I'm feeling feistier a standard Diablo Corsa.Gosling1 wrote:The symptoms you have mentioned are more likely due to incorect suspension settings than the tyre itself....
I've got no time for Pilot Powers anymore, I chewed one in 4500k down to the canvas and that is just not cool when a Supercorsa is lasting me several thousand K longer.
- Strika
Just take into consideration Weekendwarrior...that Nana's comments on grip mostly pertain to abandoned gold diggings and road Verge's! He doesn't appear to spend much time on two wheels!Pontikat wrote:In 60 thou kms on my F model 9, best Value tyre was the Shinko stealth 003.
- ty
- Team Ninja
- Bike: Honda
John,
Stick with the 180.
If you're commuting on the F3 regularly I'd say go the BT014's, or my fav was a BT012/BT020 combo.
If you're after just a rear though it'll depend on what's on the front as to what'll work - mixing brands sometimes doesn't work nice.
If you're just after weekend scratching then listen to the other guys re M3's and pilots etc
hth
ty
Stick with the 180.
hth
ty
Weekendwarrior
Hi,
Thanks for all the advice.
Yeah, just commuting really and a regular weekend ride, I am not a racer and even not sure if I am going to pursue the regular Sunday run at PITS as I am not really into the "lets see how far we can lean the machine over" thing.
I am on to what seems a good deal for a 180/55/17 Dunlop Sportmax D220, is this tyre okay for a plodder?
Does the 5% increase in height matter over the standard 50? works out about 10mm.
Regards,
John
Regards,
John
