Hi all,
just wondering if anyone knew if a regulator rectifier from a 99zx6r will work on a 91zx2r. Dont know if anyone is into electrics on this board or not? hoping someone might have an idea. I do know that kawasaki run the same regulator/rectifier on the zzr250, zx6r, zx10 and zx12, well thats what a mate told me anyway.
Thanks for any help
Regulator/rectifier Question
Re: Regulator/rectifier Question
You will need to find out the alternator output from both bikes - If they are the same (or very close), and the wiring loom plugs are the same, and the battery charging capacity (amps) is the same (or very close), then you might be in luck.christianzx6 wrote:......just wondering if anyone knew if a regulator rectifier from a 99zx6r will work on a 91zx2r. ....
Regulator/rectifier's all do *basically* exactly the same thing - the important but is the output of the alternator, and the battery amps. Wiring loom plugs can be changed pretty easily.
