ZX9R Bling Ideas
Buckets
ZX9R Bling Ideas
Post by Buckets »
As some may know, I have moved on from a sadly destroyed ZZR1100 to a 2000 Model ZX9R. I want to make some changes to it and would love some advice from you all.
Any ideas... where/what/why to get the following:
Rear Hugger
Tail Tidy/Undertray Tidy
Braided Brake lines
Also, it currently runs a 190 Rear and I reckon, after a track day last week at PI, that it would handle a bit better with a 180 on the back... any comments on that?
I would also like to get a set of Raceglass for it... suggestions again?
Thanks in advance...
Dead ZZR1100... newish ZX9R called Drago
Rossi
Post by Rossi »
Powerbronze.....check the sponsor sticky :wink:
180 will be better at the track, and in tight twisties helping u change direction...190 is better for straight line stability, and wheelies...
braided lines make a huge difference, and Supperbike supply (sponsor) have em at a good price...
http://www.superbikesupply.com.au
Buckets
Post by Buckets »
Thanks guys... exacery wot I was looking for...
ttc
Team Black
Post by ttc »
Take the fairings off, bore out the engine, put motorcross bars on it..
Oh yeah now you have a z1000 :D
Buckets
Post by Buckets »
ttc wrote:Take the fairings off, bore out the engine, put motorcross bars on it..
Why? I am happy with my nine... and it kept up with the 10's at PI last Tuesday... until it rained :(
jpbikeboy
Post by jpbikeboy »
A turbo maybe. it won't be cheap but you won't stop smiling.
Buckets
Post by Buckets »
jpbikeboy wrote:A turbo maybe. it won't be cheap but you won't stop smiling.
Now you're being silly.... :twisted:
ZX10R King
Post by ZX10R King »
I got some green headlight protectors for it.
See for sale section.
SXC in black, '05 ZX10R
Zteven
Post by Zteven »
Checkout some of my mods to an E2(2000) & lemme know what links you need mate:
http://www.ksrc-au.com/phpBB2/viewtopic.php?t=15558
I don't want a pickle, I just wanna ride my motorcycle.Image
MG
State: Overseas
Post by MG »
Neka79 wrote:braided lines make a huge difference, and Supperbike supply (sponsor) have em at a good price...
Their pricing looks ordinary to me.
The same lines ($267.95 incl p&h) they selling I paid $50 less buying em from Perth fer $219
MG
State: Overseas
Re: ZX9R Bling Ideas
Post by MG »
Braided Brake lines
I just got another set (3 lines) on ebay for under $AU50. check your PM.
ttc
Team Black
Post by ttc »
Do the cheap ones come with the yellow ADR sticker?
If not they're not legal in Aus
And brake lines vary on what fittings are used, stainless, zinc etc
MG
State: Overseas
Post by MG »
ttc wrote:Do the cheap ones come with the yellow ADR sticker?
Check the website ad. I have no use for em. Only bought to make some money.
I do know that all bolts & fittings are stainless steel.
seller wrote: USA, NEW ZEALAND, AND AUSTRAILIA
FMVSS-106 Approval
HEL Performance have obtained FMVSS-106 approval for their brake lines due to their own design of protection sleeve. Most companies who offer approved hoses have to either add a teflon skirt which detracts from the look of the hose or use a guard designed for electrical leads which are extremely hard to put on.
We can also supply the USA marketplace with DOT approval thanks to the FMVSS-106 approval our hoses obtained in both Sweden and in the UK.
Hose kits are now also being made available through a distributor in New Zealand with LVTA approval and now in Australia with ADR approval also obtained through our FMVSS-106 approval.
FMVSS-106 is a series of tests designed to put brake line assemblies through a rigorous chain of individual tests to emulate a lifetime of road use. These tests obviously show any hose assembly which is unable to comply with these requirements by failing the hose during the rigorous test cycle.
Most stainless steel braided brake line assemblies will pass all but one of the tests required to obtain full FMVSS-106 approval and these include :
Labelling, Constriction, Expansion, Burst Strength, Whip Resistance, Tensile Strength, Low Temperature Resistance, Brake Fluid Compatibility and End Fitting Corrosion Resistance
All of the above requirements should be able to be met by any manufacturer with the exception of the Whip Resistance test due to the properties of the stainless steel braid. This test states 'A hydraulic brake hose assembly shall not rupture when run continuously on a flexing machine for 35 hours.'
HEL Performance have met this requirement by the inclusion of our own special guards which simply heat shrink onto the hose leaving a clean and uncluttered end.
ALL LINES COME WITH A LIFETIME WARRANTY FROM HEL PERFORMANCE UK AND THE WARRANTY REGISTRATION CARD IS ENCLOSED IN THE KIT.
MG
State: Overseas
Post by MG »
Yet another selling heaps cheaper..
$AU146 includes delivery
http://cgi.ebay.co.uk/HEL-3-BRAKE-LINE- ... dZViewItem
