fitting an after market exhaust
Agent445
Post by Agent445 »
Hi Guys,
I just fitted a bolt on termignoni to my 05 ZX10, It was not an exact fit to the bracket on the pillion pegs, I had to push the muffler up about 2cm for it to reach the bracket.
My question is.
Pushing it up those 2cm will it put to much of strain on the rest of the exhaust, and will this do any damage to exhaust?
I think it probably will not , but I would be interested to here your expert point of views.
Hard to say without seeing it, although I doubt whether you could do too much damage. How come it didn't fit properly, not the right one for the bike?
mfzx6r
Post by mfzx6r »
Pics ??
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
termi....hmmm nice.... pics would be nice..and show the bit that doesnt line up...
does it leak air??
Neka79 wrote:does it leak air??
that would be my first question too, sounds like somethings not right somewhere.
Errol
Post by Errol »
Maybe you need to loosen the header pipes, (which usually means fitting new exhaust gaskets) prior to bolting up the end can. Try to spread the load over the whole system rather than just the end can & joint area.
Back in Black 2001
1/4 mile Best MPH 129.47
Best ET 10.747
Stretchy
Post by Stretchy »
Its the same on my ZX10Rs as well, slipon and full system. The weight of the whole exhaust system is only held on at the head and where that bracket is.
As long as its not on some weird angle that could damage the system you should be right.
O5 ZX10R Superduperbike
ZX7R
Stay on the gas...maybe you'll save it, maybe you won't, but at least it will end the suspense....
"If everything seems like its under control, you are not going fast enough." - Mario Andretti
