Problem starting bike on cold mornings
- Adel
Ok experts I need your expertise on what is good way to start bike on cold mornings or may b there isnt a way you say' well it happend a couple of times already where I try startn the bike but not any sign of firing happens and I keep goin until the battery starts showin signs of fatigue then i stop its only when I clutch start it only will it start ok, cant b moisture cause I keep it garaged could it b fuel ? I use Optimax or that BP stuff only so any one got any ideas peoples please please please, as some of you would know it is a 02 R1 so leave the the smart ass comment out of it for now
ZXR 750 j 91
Re: Problem starting bike on cold mornings
Get your battery tested, could be on the way out causing hard starting even if it seems to be cranking over OK
and if it needs replacing, go with a *Genuine* japanese-build Yuasa. Not the Taiwan copies.
I have had a jap-made Yuasa in the Black Pearl now for over 5 years, it still cranks it over every time, has never lost charge, and doesn't need re-charging between long stints in the shed. The guy who sold it to me recommends these Yuasas as "the only battery that will start a bike right through a Canberra winter..." - food for thought.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
its a yamy thing ...Adel wrote:Ok experts I need your expertise on what is good way to start bike on cold mornings or may b there isnt a way you say' well it happend a couple of times already where I try startn the bike but not any sign of firing happens and I keep goin until the battery starts showin signs of fatigue then i stop its only when I clutch start it only will it start ok, cant b moisture cause I keep it garaged could it b fuel ? I use Optimax or that BP stuff only so any one got any ideas peoples please please please, as some of you would know it is a 02 R1 so leave the the smart ass comment out of it for now
sorry couldnt resist...
how long since its been serviced?? are the plugs healthy and clean?? timing etc is good?? is it carb or EFI?? and either way, has that been looked at lately??
cold weather isnt great for a battery...how often do u ride the bike?? daily?? maybe the battery isnt holding a good charge?? (cold weather would put a bit extra pressure on it)...
i'd get out the ole multi meter and do a battery check 1st..cos its pretty easy... maybe check ur plugs if they arent too hard to get to..??
- Adel
Thankin you Mr Mick C and Mr Gosling will look into it rite away
ZXR 750 j 91
- Adel
Neka79 wrote:its a yamy thing ...Adel wrote:Ok experts I need your expertise on what is good way to start bike on cold mornings or may b there isnt a way you say' well it happend a couple of times already where I try startn the bike but not any sign of firing happens and I keep goin until the battery starts showin signs of fatigue then i stop its only when I clutch start it only will it start ok, cant b moisture cause I keep it garaged could it b fuel ? I use Optimax or that BP stuff only so any one got any ideas peoples please please please, as some of you would know it is a 02 R1 so leave the the smart ass comment out of it for now
cheers![]()
It is an EFI and I did get it serviced when I first got it in april, now that every one said it I will get the battery testd and may b if it continues I'll take it for anotha service ( bloody costly services )
ZXR 750 j 91
- Neka79
- Bike: Z900
try the battery 1st... check that its getting enuf charge too.... and that its holding it...Adel wrote:Neka79 wrote:its a yamy thing ...Adel wrote:Ok experts I need your expertise on what is good way to start bike on cold mornings or may b there isnt a way you say' well it happend a couple of times already where I try startn the bike but not any sign of firing happens and I keep goin until the battery starts showin signs of fatigue then i stop its only when I clutch start it only will it start ok, cant b moisture cause I keep it garaged could it b fuel ? I use Optimax or that BP stuff only so any one got any ideas peoples please please please, as some of you would know it is a 02 R1 so leave the the smart ass comment out of it for now
cheers![]()
they reckon a bike system doesnt charge til abt 5000rpm or more, so make sure when u test it u give it sum revs (this way u can make sure ur voltage reg is working, and its not cooking ur batt).... do u do really short rides or long-ish rides??
- Adel
A bit of everything really so as far as battery chargin I did plenty ridin for that , when I first kick it ova it turns ok but just dont want to igniteNeka79 wrote: do u do really short rides or long-ish rides??
ZXR 750 j 91
- Neka79
- Bike: Z900
yea even tho the battery is ok in warmer weather, sumtimes the cold weather causes probs..it might seem ok..but the cold hurts it..Adel wrote:A bit of everything really so as far as battery chargin I did plenty ridin for that , when I first kick it ova it turns ok but just dont want to igniteNeka79 wrote: do u do really short rides or long-ish rides??
