ZX6R 05 Transmission problem
- aus636
Is there a problem with these bikes transmission with them jumping out of 2nd gear. As I was on the US forum and there seems to be a few people with this problem. http://kawiforums.com/forum/topic.asp?T ... hichpage=5" target="_blank
Re: ZX6R 05 Transmission problem
I have heard they can have probs, im prayin my bike never has problems cause my warranty is screwed cause i refuse to pay those rediculous prices for a service.
Life is too short for traffic.
- MrStompy
ive heard reports of it as well.
ive never met anyone with the problem though and luckily enough i have had no problems with mine.
hopefully it will stay that way
- aus636
I wonder if it has got something to do with European(Aust) spec bike and the American spec.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
more importantly do YOU have probs with it??aus636 wrote:Is there a problem with these bikes transmission with them jumping out of 2nd gear. As I was on the US forum and there seems to be a few people with this problem. http://kawiforums.com/forum/topic.asp?T ... hichpage=5" target="_blank" target="_blank
dont foget, as u stated below, different specs for diff countries..also different licensing arrangements..ive heard that a lot of the US guys dont go thru wot we go thru...so they may hurt their bikes with bad gear changes etc?? maybe??
Any bike will have problems with an abused transmission. Second is the most common failure. Way back when, I was seriously considering a YZF-600R and got told horror stories about 2nd gear problems.
A bit of research showed that there's a demographic on every single sporting 600 that has issues with second gear. Funny, that.
- aus636
It seems that way with the US forum.
No problem with the bike apart from lazey shifting and it has 20000km.
my Z1000 jumped out of fouth quite a few times on track days, but it did have a bit of a hard life. only 6000 kms on it too
- Neka79
- Bike: Z900
i dont wanna hear that kinda talk!!matt76 wrote:my Z1000 jumped out of fouth quite a few times on track days, but it did have a bit of a hard life. only 6000 kms on it too
If your Zed ain't doin' it , you have nothing to worry about.
the problem with reports like this is that you only ever hear *one* side of the story, not the side that says *multiple drag starts on every Friday night at the local street races* - performed by some gumby fuckstick with 2 left feet, who then has the nerve to whinge about his bike being a piece of crap because * all of a sudden its jumping out of 2nd gear...*
My Zed seemed very sensitive to having the right chain tension. So check this first if you have any problems, I used to run mine too tight, but loosening it up seemed to help a lot
- aus636
I agree there is always two sides of a story.Gosling1 wrote:If your Zed ain't doin' it , you have nothing to worry about.
the Yanks are *legendary* for this type of story - I take anything read on US forums with a bucket of salt.....
the tip about chain tension is good, this is often the cause of bad shifts, and it can make the gearbox play up a bit as well.
If your 6 starts jumping out of 2nd or 3rd under normal acceleration, then you will have a problem with worn gear dogs. Swabio had a problem on his 6 this time last year, it got replaced under warranty I think ? Occasionally, the selector fork return spring loses tension and/or breaks, and this will also cause problems with changing gear. But 'jumping' out of gear is generally always because the gear 'dogs' are worn and don't keep engaged under pressure.....
Exactly what Gos said.
The most common cause for premature wear in the dogs is getting back into the throttle too quick when changing, before the gear is properly engaged. Either trying too hard to go quick (a la the drag race starts), or being lazy (slow) on the change. One way to avoid this is to install a shift kit, the stronger springs of which will engage the gear more firmly (faster). Another is to shift correctly.
