Dont think its stretched the sprockets are fine the bike has only done 4000ks any ideas what might be causing this?
Any help or ideas really appreciated!
Graeme
Depending on use and time sitting etc., a chain can very early in it's life develop one or two tight spots. ie; the chain has stretched, but not as much in one or more parts of the chain. This can somewhat cause this surging feeling. Maybe just......"Trade it in"!graemec wrote:Ok my chain seems to be ok (i think) i just adjusted it after buying the bike as it was quite loose.
Any help or ideas really appreciated!![]()
Graeme
maybe its either adjusted too tight (sounds like it) or if it has tight spots, u have adjusted it at a loose spot.. if u have a rear stand put it up and turn the wheel to see how it runs...graemec wrote:Ok ill check out the stretching thang, did not seem to surge really b4 the tighten up.
Might try backing it off a fraction though the tension is right on the money according to the service manual.
As for selling it ive had it less than a week! Hmmmm.... naw the girl would kill me![]()
