Trickle charger
Trickle charger
Hi guys,
Can anyone recommend a trickle charger? something like the "battery tender" with a wiring harness to easily hook it up each time you park the bike.
Cheers.
Cheers.
Re: Trickle charger
Have a listen to this guy. has a lot of reveiws on numerous bike accesseries.
http://motorcyclemania.com.au/category/ ... ttery-doc/" target="_blank
[IMG]http://i50.tinypic.com/2cohlwg.jpg[/IMG]
- red_dave
- Team Kuda
Re: Trickle charger
Battery Fighter Junior...
http://www.master-instruments.com.au/pr ... FJ012.html
Most Battery World's and Super Cheap Auto's have them. It's a fully automatic charger anf heaps better than the Projecta/Arlec versions out there.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
Re: Trickle charger
oh yea.... forgot abt u ..Mr battery man!!red_dave wrote:Battery Fighter Junior...
Dave knows his batteries... so listen to the man....
- Smitty
Re: Trickle charger
I bought a trickle charger from the battery man..Dave
one of these for my Zx12r...sweet
http://www.master-instruments.com.au/pr ... B3517.html" target="_blank
- aus636
Re: Trickle charger
Go to Supercheap $49 works OK for me.
- Team Naked
Re: Trickle charger
That because you never ride it Smitty?Smitty wrote:I bought a trickle charger from the battery man..Dave
http://www.master-instruments.com.au/pr ... B3517.html" target="_blank" target="_blank
- Neka79
- Bike: Z900
Re: Trickle charger
why dont u just ride the damn things?
ive never used one of these...and my bikes start...
Re: Trickle charger
Thanks guys,
I ended up getting the jnr battery fighter from super cheap for only $49. Now I have to make sure the battery has water in it, and that the charger is hooked up correctly. The intructions go on about whether the battery is positively grounded or negatively grounded. How the hell woul I tell, and does it really make a difference? otherwise i'll just hook it up to both battery posts.
- Rossi
Re: Trickle charger
Always negative grounding on bikes mateidh959 wrote:Thanks guys,
- Smitty
Re: Trickle charger
a test for a Brit
was it the Ariel, BSA, Triumph, AJS, Norton, Royal (Enfield), Beardmore, Sunbeam, Vincent, Excelsior or Matchless bikes
(or none ) that had pos earth...???
and a bit of trivia.... David Brown built the first Aston MArtins (DB1- 4 cyl and DB2-6cyl ) with positive earth electricals
which meant strange gear from Lucas and SU (who made the electric fuel pumps)
Re: Trickle charger
You need to make sure you hook it up correctly, otherwise you will immediately fuck your brand new charger !!! Yes it makes a huge difference, reversing the polarity from a battery charger could be lethal if you have any petrol fumes in the area.idh959 wrote:...... The intructions go on about whether the battery is positively grounded or negatively grounded. How the hell woul I tell, and does it really make a difference? otherwise i'll just hook it up to both battery posts.....
Your bike will be a negative earth. Attach the positve (red) charger lead to the battery +ve terminal, and the earth lead (black) to a solid point on the frame, either a footpeg mount, engine bolt, somwehere like that.
You could also take the battery right out of the bike and charge it, if you wanted to.
If you want to hook up a 'battery tender' type charger, you need to wire in a plug somewhere on the bike, so the battery tender can simply plug in and start charging. If you are not real sure about electrics, get this done by an auto-electrician.
ps - Yoda - I am sure that post-war Nortons had +ve earth, and maybe even the Matchies ?? what a crock of shit +ve earth was eh ??
- Smitty
Re: Trickle charger
definitely the Matchies ...and some Nortons AFAIK
positive earth is a very strange setup
