Going down the road... Naked...
Tnate
Post by Tnate »
Can someone please point me in the right direction (Forum or otherwise)
I'm contemplating turning my ZXR 750 (1994) into a naked sports bike.
Is there anywhere where I can get a list of available parts, parts I'll need etc. from around the Melbourne area.
Any help would be grande.
Tnate
Re: Going down the road... Naked...
you need to check out places like Austreetfighter etc. There is a heap of different stuff you can buy, but not a 'list' as such, streetfighters are a really personal expression, so its really up to you what you buy and fit to your rig.
Check out RAPID bikes as well for ideas, etc. Good luck - if you can post some pictures that would be great !
aus streetfighters have a bunch of gear...ummm...
http://ausfr.com.au/" target="_blank
there is an aussie street fighter forum... dunno wot it is, greeny reckons its ok tho... google it?
99coconuts
Post by 99coconuts »
these guys neka... http://www.streetfighters.com.au/" target="_blank
but i reckon trial and error mixed with a little imagination will get you there. if you want some ideas just have a look around at some picstures of other peoples bikes or even better, check some out in person.
but to your bike... it should be VERY similar to mine, off the top of my head:
-you'll need to organise a new coolant overflow bottle, i have a pub squash bottle under my seat where the tool box would go. not perfect, but it works.
-you will have some faring mounts hanging off your motor, its unavoidable, they're a part of the side covers.
-most cheaper headlight mounts are made for conventional forks, before you buy anything make sure they'll fit your forks.
-buy a digital dash, it'll save farking around trying to make the standard one look reasonable, at $200ish, its money well spent i think.
-you're gunna have a bit of fun getting the MX bar mounts right (make sure you have enuff clearance in between them to do up the top triple bolt and you may need to cut the mount bolts down so they dont scrape your frame).
-with mx bars, your throttle, clutch and choke cables will reach (just) but your brakes wont, you can get a new longer section made up at an auto brake shop for around $50 or buy a set of longer braided lines.
-having the ram air disconnected seems to have made feck all difference, but i made this mod at the same time http://homepage.ntlworld.com/webzxr/zxr ... tbowl.html" target="_blank
-wind is a bitch at 200kph :shock:
-streetfightered bikes look hell cool 8)
racing hondas is like running in the special olympics
win or lose, you're still a honda rider...
99 ZX7R streetfighter
76 HJ Wagon kiddiekart
71 HQ coupe
http://www.99coconuts.com" target="_blank
jeebuz, 3 kids now.... anyone want one? free to a good home!
99coconuts wrote:-wind is a bitch at 200kph :shock:
both these comments are correct....
however i have noticed on a naked/fighter ..that once u get to abt 130+, the wind factor makes things seem like 200kph anyway...
