Need some advise. My Chain has developed a 'tight spot'. I noticed my chain had way too much slack, about 3 inches! so i adjusted the chain to a normal 1-1.5inch flex, as i turned the wheel the flex was all the same except for this 1 spot where it was very tight and had no flex.
(yes the back wheel is on straight)
I reckons i need new chain and sprockets, i've put about 12,000kms on the bike in the last 2.5 years (second hand before that so i've no idea when the chains and sprockets were changed)
So questions are.. 1996 ZX6R ninja
1. Trying to find exact size of front and rear sprockets - i think its 40 tooth rear 15 tooth front with 525 108 link chain- Can anyone confirm this for me at all???
2. Was thinking it would be cheaper buying the chain and sprockets online then taking to mechanic for installation, what brand would you recommend?? RK or DID ?
3. Whats the best chain type? X-ring o-ring?
4. How much should i expect to pay for a mech to install?
5. And Finally if i wanted say.. more bottom end power / torque what rear / front combo would you recommend and what chain would suit the number of sprocket links suggested?
Awesome thanks!!!
