rebuilding.....
swabio-ACT
rebuilding.....
Post by swabio-ACT »
well after attempting to kill my trackbike back in April..... then skipping the country for six months.... the time has come to rebuild it...... with pretty much all the spanner work being done by a mate of mine.... (and bonesters!)
here are some pix so far....
SoundGuy
Re: rebuilding.....
Post by SoundGuy »
Go you good thing !!! 8)
Re: rebuilding.....
Hurry up the new season will start soon! :P
swabio-ACT
Re: rebuilding.....
robracer wrote:Hurry up the new season will start soon! :P
Yeah, yeah..... Bloody kwaka bits take ages to get here :( I have to wait for the thermostat housing to arrive from Japan...... :( But i just found a second hand one from a wrecker in nowra! So yeah, it should be going again soon.......
Re: rebuilding.....
Get into it mate !! will be great to see the 6 back up and firing in NE2 :twisted:
swabio-ACT
Re: rebuilding.....
Got the shims today... so the cams are back in..... carbies on.....so it is getting there..... I will sort it out over the next couple of weeks and it will be ready for the new year ;)
I can't wait to get it done......
There is one little problem to be fixed though.. and that is the rear rim has a bit of a buckle.... so will have to see about getting it straightened! it is not too bad, and I can just run with the spare rims which are straight as anyway!
Re: rebuilding.....
cool idea run the spare rim 8) BTW thanks for the posted item it arrived today ;)
swabio-ACT
Re: rebuilding.....
robracer wrote:cool idea run the spare rim 8) BTW thanks for the posted item it arrived today ;)
cool, let me know if you have any problems with it!
dave#3
Re: rebuilding.....
Post by dave#3 »
swabio-ACT wrote:There is one little problem to be fixed though.. and that is the rear rim has a bit of a buckle.... so will have to see about getting it straightened! it is not too bad, and I can just run with the spare rims which are straight as anyway!
Laurie Alderton (or more correctly Dave, his sidekick) will fix the rim. Probably about $90 and a few days turn-around.
http://www.oz4x4.net/gallery2
swabio-ACT
Re: rebuilding.....
Cheers Dave,
I may have to send it up.....
Re: rebuilding.....
Cheers Dave,
If you go down that route let me know as I have client in the same street as Laurie so I could slip out for a delivery / pick up / network & do the logistics from this end :D Laurie has done a rim for me amongst many other fixes & mate the rim came out perfect!
Re: rebuilding.....
Laurie Alderton is a dead-set legend from way back - if he is doing the work on your rims mate, you'll be fine.
There used to be a mob over in Queanbehole who did this, but they closed the shop about 4 years ago.... :(
swabio-ACT
Re: rebuilding.....
robracer wrote: If you go down that route let me know as I have client in the same street as Laurie so I could slip out for a delivery / pick up / network & do the logistics from this end :D Laurie has done a rim for me amongst many other fixes & mate the rim came out perfect!
Cheers Rob,
I may just do that......
