ZZR 600 crash knobs
ZZR 250, 600, 1100 & 1200
Marty ZZR rider
ZZR 600 crash knobs
Post by Marty ZZR rider »
Hi I am a newbie and this is my first post:
Does anyone know where I can get a set of crash knobs for a 2004 ZZR600?
I notice some bike models are advertised as no-cut, but I,ve been told these are inferior on some bikes such as mine as they are only mounted to the sub-frame. And may do more damage than good in the case of a serious slide.
Who's got the clues? Cheers Marty.
I am currently in the process of putting a ZZR 250 motor from a 2006 model into my son's 1990 model.
My second post will probably be tomorrow if it doesn't fire.
Re: ZZR 600 crash knobs
There is an online shop on Ebay UK, called UKGPshop. It has loads of other stuff but amongst what they sell are crash style crash knobs. They appear to be really good value, with a set costing about $60 landed here in Oz, compared to, up to around $200 for the local stuff. :) I always try and support someone local when possible, but when the smallest price difference was $100, I'll go online! :roll:
Marty ZZR rider
Thanks Strika I'll have a look and let you know how I get on.
ty
Bike: Honda
Post by ty »
I got some R&G import ones from the UK - required cutting though.
Have a look at http://www.ksrc-au.com/index.php?itemid=94
ty
Marty ZZR rider
Thanks
How did they turn out? I bet cutting a nice hole in that sloped surface was bastard.
What did you use to cut the fairings?
I have to fit them I think there is something wrong with the design of the small stand I have heard too many rolled off the stand stories.
ty
Bike: Honda
Post by ty »
When I did those I used a spade drill bit thinking that would do the job - should've used a hole saw in hindsight.
Apart from that they worked well - saved the bike on a driveway fall, and when a 4x4 backed into it.
Didn't help too much when I flipped it though :oops:
The R&G knobs are an engine mount setup - with a rod going between the two knobs behind the headers. So they're pretty strong.
The cheaper - frame mount - ones risk breaking mounts off the frame in an off.
I've only heard of this via the grape-vine - most people don't seem to have a problem.
hth
ty
Marty ZZR rider
Thanks for the reply I have heard the same thing about the cheaper no cut knobs.
dave#3
Post by dave#3 »
ty wrote:When I did those I used a spade drill bit thinking that would do the job - should've used a hole saw in hindsight.
hth
ty
I had a set of Kaneg's frame sliders on my 9 when I crashed it recently at the track. They did a fantastic job.
http://www.oz4x4.net/gallery2
Marty ZZR rider
From the looks of that fairing they did do a fantastic job. It looks like they are a fairly worthwhile investment.
SoundGuy
Post by SoundGuy »
Yes give Kaneg a call...
I have a set on my 10 8)
