*SOLVED* Computer Problem Tech Question
tape
Post by tape »
My computer when starting up makes sounds like it's a wannabe remote control aeroplane :shock:
Is it likely to be fan, power supply or hard drive?
Would appreciate helpful advice.
Mick :drinkers:
http://www.insptag.com.au
onewheelmat
Re: Computer Problem Tech Question
Post by onewheelmat »
check the fan it could have become clogged up with dust or maybe somethings obstucting it.
or maybe get a new one???
all bike were created equal, its just Kawasaki were created more equal than the rest.
tape
Post by tape »
Just removed and cleaned fan and it seems more the power supply is the noise maker...
It's a Bliss Power Supply ATX-300, should I replace with same or is there a better alternative out there?
Mick :drinkers:
MrWasabi
Post by MrWasabi »
if its making noise there are 2 options.
1 take the fan out, clean it and lube it up. To do this you need to peel back the sticker from the middle of the fan and remove a rubber grommit. you put a small amount of sewing machine oil in there or similar.
replace the grommit and should be good as new.
Word of warning, not all fans have this grommit, some fans are made to not be serviceable, they just get thrown away when they get old.
Now if you cant be stuffed doing that, get a new one.
For the sake of $50, you can purchase a brand new one. Same brand and a bit of an upgrade to your 300w.
http://www.techbuy.com.au/p/56806/POWER ... TX-400.asp
basically you shouldnt need any higher wattage PSU if you dont intend on putting more gear in your PC. but for $50 whos complaning?
Mistakes:
tape
Post by tape »
Problem solved...
It was the power supply $35 for a 500 and it took ten minutes for me to change over the PS and she's as quiet as a church mouse.
Thanks for the advice.
Mick :drinkers:
hey my mate worked at Techbuy.. i thought they went dead... 8)
daffy67
Re: *SOLVED* Computer Problem Tech Question
Post by daffy67 »
Don't pay much attention to the wattage rating-look at how many amps are put out on the 12v rail if you have a modern system. If it's your average office/internet pc then what you bought will suffice, but with any modern gaming oriented pc then a garden variety PSU is not always the best option.
Blue '07 ZX-10
