The Pace How to ride the street..
Since we have a few new members I thought I would post this as a reminder of how to ride the street as part of a KSRC ride..
I also went up the old road and saw some foolish riding behaviour from some temporary citizens today..this is what has prompted me to put this up..
Remember it's not how fast you, its how smooth you are, OK..
THE PACE
The street is not the track — It's a place to Pace
Two weeks ago a rider died when he and his bike tumbled off a cliff paralleling our favorite road. No gravel in the lane, no oncoming car pushing him wide, no ice. The guy screwed up. Rider error. Too much enthusiasm with too little skill, and this fatality wasn't the first on this road this year. As with most single-bike accidents, the rider entered the corner at a speed his brain told him was too fast, stood the bike up and nailed the rear brake. Good-bye.
On the racetrack the rider would have tumbled into the hay bales, visited the ambulance for a strip of gauze and headed back to the pits to straighten his handlebars and think about his mistake. But let's get one thing perfectly clear: the street is not the racetrack. Using it as such will shorten your riding career and keep you from discovering the Pace. The Pace is far from street racing � and a lot more fun.
The Pace places the motorcycle in its proper role as the controlled vehicle, not the controlling vehicle. Too many riders of sport bikes become baggage when the throttle gets twisted — the ensuing speed is so overwhelming they are carried along in the rush. The Pace ignores outright speed and can be as much fun on a Ninja 250 as on a ZX-11, emphasizing rider skill over right-wrist bravado. A fool can twist the grip, but a fool has no idea how to stop or turn. Learning to stop will save your life; learning to turn will enrich it. What feels better than banking a motorcycle over into a corner?
The mechanics of turning a motorcycle involve pushing and/or pulling on the handlebars; while this isn't new information for most sport riders, realize that the force at the handlebar affects the motorcycle's rate of turn-in. Shove hard on the bars, and the bike snaps over; gently push the bars, and the bike lazily banks in. Different corners require different techniques, but as you begin to think about lines, late entrances and late apexes, turning your bike at the exact moment and reaching he precise lean angle will require firm, forceful inputs at the handlebars. If you take less time to turn your motorcycle, you can use that time to brake more effectively or run deeper into the corner, affording yourself more time to judge the corner and a better look at any hidden surprises. It's important to look as far into the corner as possible and remember the adage, "You go where you look."
DON'T RUSH
The number-one survival skill, after mastering emergency braking, is setting your corner-entrance speed early, or as Kenny Roberts says, "Slow in, fast out." Street riders may get away with rushing into 99 out of 100 corners, but that last one will have gravel, mud or a trespassing car. Setting entrance speed early will allow you to adjust your speed and cornering line, giving you every opportunity to handle the surprise.
We've all rushed into a corner too fast and experienced not just the terror but the lack of control when trying to herd the bike into the bend. If you're fighting the brakes and trying to turn the bike, any surprise will be impossible to deal with. Setting your entrance speed early and looking into the corner allows you to determine what type of corner you're facing. Does the radius decrease? Is the turn off- camber? Is there an embankment that may have contributed some dirt to the corner?
Racers talk constantly about late braking, yet that technique is used only to pass for position during a race, not to turn a quicker lap time. Hard braking blurs the ability to judge cornering speed accurately, and most racers who rely too heavily on the brakes find themselves passed at the corner exits because they scrubbed off too much cornering speed. Additionally, braking late often forces you to trail the brakes or turn the motorcycle while still braking. While light trail braking is an excellent and useful technique to master, understand that your front tire has only a certain amount of traction to give.
If you use a majority of the front tire's traction for braking and then ask it to provide maximum cornering traction as well, a typical low-side crash will result. Also consider that your motorcycle won't steer as well with the fork fully compressed under braking. If you're constantly fighting the motorcycle while turning, it may be because you're braking too far into the corner. All these problems can be eliminated by setting your entrance speed early, an important component of running the Pace.
Using all of the available lane while entering the corner (square line) provides a number of benefits. It allows you to brake while upright, see farther through the corner and use a later corner apex. With a later apex, you can get on the throttle earlier as you stand the bike up out of the corner. The low entrrance line (dotted line) forces you to lean over even after the apex and is a major contributing factor to overshooting a corner. Always give the centerline some room; stay right except to pass.
Since you aren't hammering the brakes at every corner entrance, your enjoyment of pure cornering will increase tremendously. You'll relish the feeling of snapping your bike into the corner and opening the throttle as early as possible. Racers talk about getting the drive started, and that's just as important on the street. Notice how the motorcycle settles down and simply works better when the throttle is open? Use a smooth, light touch on the throttle and try to get the bike driving as soon as possible in the corner, even before the apex, the tightest point of the corner. If you find yourself on the throttle ridiculously early, it's an indication you can increase your entrance speed slightly by releasing the brakes earlier.
As you sweep past the apex, you can begin to stand the bike up out of the corner. This is best done by smoothly accelerating, which will help stand the bike up. As the rear tire comes off full lean, it puts more rubber on the road, and the forces previously used for cornering traction can be converted to acceleration traction. The throttle can be rolled open as the bike stands up.
A tire has a given amount of traction that can be used for cornering, accelerating, decelerating or a combination of these. A tire that's cornering hard won't have much traction left for acceleration or deceleration. Imagine a linkage connecting your rear tire to your throttle hand. As the tire stands up from full lean, your throttle can be rolled open; the tire's traction used for cornering can now be converted to acceleration traction.
This magazine won't tell you how fast is safe; we will tell you how to go fast safely. How fast you go is your decision, but it's one that requires reflection and commitment. High speed on an empty four-lane freeway is against the law, but it's fairly safe. Fifty-five miles per hour in a canyon may be legal, but it may also be dangerous. Get together with your friends and talk about speed. Set a reasonable maximum and stick to it. Done right, the Pace is addicting without high straightaway speeds.
The group I ride with couldn't care less about outright speed between corners; any gomer can twist a throttle. If you routinely go 100 mph, we hope you routinely practice emergency stops from that speed. Keep in mind outright speed will earn a ticket that is tough to fight and painful to pay; cruising the easy straight stuff doesn't attract as much attention from the authorities and sets your speed perfectly for the next sweeper.
Using your brakes entering a corner, or trail braking, takes a delicate touch on the lever. As the bike leans in and the tire begins cornering in earnest, there won't be much traction left for braking. Imagine a connection between the front-brake lever and the front tire: as the tire goes to full lean, all traction will be used for cornering; grabbing the front brake at this point will lock the front wheel.
GROUP MENTALITY
Straights are the time to reset the ranks. The leader needs to set a pace that won't bunch up the followers, especially while leaving a stop sign or passing a car on a two-lane road. The leader must use the throttle hard to get around the car and give the rest of the group room to make the pass, yet he or she can't speed blindly along and earn a ticket for the whole group. With sane speeds on the straights, the gaps can be adjusted easily; the bikes should be spaced about two seconds apart for maximum visibility of surface hazards.
It's the group aspect of the Pace I enjoy most, watching the bikes in front of me click into a corner like a row of dominoes, or looking in my mirror as my friends slip through the same set of corners I just emerged from.
Because there's a leader and a set of rules to follow, the competitive aspect of sport riding is eliminated and that removes a tremendous amount of pressure from a young rider's ego — or even an old rider's ego. We've all felt the tug of racing while riding with friends or strangers, but the Pace takes that away and saves it for where it belongs: the racetrack. The racetrack is where you prove your speed and take chances to best your friends and rivals.
Riding fast everywhere hurts our image, your license and eventually your bike and body. Set realistic freeway and city speed limits, stick to them and save the speed for the racetrack or dragstrip.
I've spent a considerable amount of time writing about the Pace (see Motorcyclist, Nov. '91) for several reasons, not the least of which being the fun I've had researching it (continuous and ongoing). But I have motivations that aren't so fun. I got scared a few years ago when Senator Danforth decided to save us from ourselves by trying to ban superbikes, soon followed by insurance companies blacklisting a variety of sport bikes. I've seen Mulholland Highway shut down because riders insisted on racing (and crashing) over a short section of it. I've seen heavy police patrols on roads that riders insist on throwing themselves off of. I've heard the term "murder-cycles" a dozen times too many. When we consider the abilities of a modern sport bike, it becomes clear that rider technique is sorely lacking.
The Pace emphasizes intelligent, rational riding techniques that ignore racetrack heroics without sacrificing fun. The skills needed to excel on the racetrack make up the basic precepts of the Pace, excluding the mind-numbing speeds and leaving the substantially larger margin for error needed to allow for unknowns and immovable objects. Our sport faces unwanted legislation from outsiders, but a bit of throttle management from within will guarantee our future.
THE PACE PRINCIPLES
Set cornering speed early. Blow the entrance and you'll never recover.
Look down the road. Maintaining a high visual horizon will reduce perceived speed and help you avoid panic situations.
Steer the bike quickly. There's a reason Wayne Rainey works out — turning a fast-moving motorcycle takes muscle.
Use your brakes smoothly but firmly. Get on and then off the brakes; don't drag 'em.
Get the throttle on early. Starting the drive settles the chassis, especially through a bumpy corner.
Never cross the centerline except to pass. Crossing the centerline in a corner is an instant ticket and an admittance that you can't really steer your bike. In racing terms, your lane is your course; staying right of the line adds a significant challenge to most roads and is mandatory for sport riding's future.
Don't crowd the centerline. Always expect an oncoming car with two wheels in your lane.
Don't hang off in the corners or tuck in on the straights. Sitting sedately on the bike looks safer and reduces unwanted attention. It also provides a built-in safety margin.
When leading, ride for the group. Good verbal communication is augmented with hand signals and turn signals; change direction and speed smoothly.
When following, ride with the group. If you can't follow a leader, don't expect anyone to follow you when you're setting the pace.
Re: The Pace How to ride the street..
Ohh Yeah....this is what happens when the pace is not followed !!
putty 6 small.jpg (118.75 KiB) Viewed 4021 times
Slow and wobbly
Post by Slow and wobbly »
hoffy wrote:Ohh Yeah....this is what happens when the pace is not followed !!
Offerings to the gods of speed.
I liked this bit the most...
"......GROUP MENTALITY
Because there's a leader and a set of rules to follow, the competitive aspect of sport riding is eliminated and that removes a tremendous amount of pressure from a young rider's ego — or even an old rider's ego. We've all felt the tug of racing while riding with friends or strangers, but the Pace takes that away and saves it for where it belongs: the racetrack. The racetrack is where you prove your speed and take chances to best your friends and rivals......"
ty
Bike: Honda
Post by ty »
I find it amusing that you posted this Hoffy - pot, black, and all that ;)
All good points though - we can all learn from this and reset our brains.
It's easy for any of us to get complacent and need these reminders, no matter how long we've been riding for.
ty
I really like this theory, and try to adopt it where I can. I have already been asked, "Are you going to use your breakes today" as we completed a nice section to the Great Ocean Road. Problem is, I don't get to the race track enough :twisted:
Nelso
Post by Nelso »
ty wrote:I find it amusing that you posted this Hoffy - pot, black, and all that ;)
I followed Hoffy through the twisties last weekend and thought he set a good pace. 8)
I cant remember the last time I rode with you at 'The Pace', however I have found it to be a good safe way to ride and develop my skills...help me understand exactly what you mean ??
dave#3
Post by dave#3 »
Sorry Tony, but to be fair, we've all changed our riding and our attitudes since that photo was taken - some perhaps more than others - and I can assure you that Hoffy is a strong proponent and skilled executioner of riding 'the pace'. Any suggestion to the contrary is not fair IMO.
http://www.oz4x4.net/gallery2
Damon Z1000
Post by Damon Z1000 »
:cry: :cry: :cry:
Team Crash 2010 Ooooops
myk1979
Post by myk1979 »
Thanks for posting that hoffy, it made for a good and very interesting read. As a new member to both KSRC and the riding community in general i find articles like this to be very helpful to my learning and really appreciate guys like yourself bringing them to our attention. I always try to ride to the best of my ABILITIES but I'm the first to admit that i've made some stupid mistakes along the way while finding my limits and trying to further them, but at the same time i've really learnt from them!!
Anyway just really wanted to say thanks for posting the article mate!
This beer is making me AWESOME!
Hey Hoffy!
That was really good reading and emphasised what I thought I should be working on! So thanx for re-posting it and Ill take in onboard! 8)
ty
Bike: Honda
Post by ty »
All right - I'll take the return on the chin.
I wasn't trying to be nasty - I would've expected someone to say something similar to me if I'd've posted this.
It was intended to be tongue-in-cheek.
Sorry Hoff.
ty
Shifty
Post by Shifty »
I have actually banned myself from group rides for this reason. I'm not an idiot, just for some reason my self control dwindles when there is a hint of competition. I would be more inclined to come along on 'pace' rides but I just avoid the 'group rides' sections on various forums as 9/10 rides get a bit out of control for me.
A mid-size grunter is perfect for this type of riding, CB900 or similar would be perfect... light & easy to handle, wide bars for fun cornering etc.
Perhaps a Z750 as well, but just to stir the pot they're a bit of a girl's bike.
hoffy wrote:Since we have a few new members I thought I would post this as a reminder of how to ride the street as part of a KSRC ride..
Hofster...good post
lots of top riding points listed there
nice to see my ol' 'slow in fast out ' gets a mention
