OK i'm out of the closet and got heated hand grips
I have vented gloves for most of the year and things like boxing gloves for winter
that I want to ditch.
what gloves work well with heated grips?
I'm in vic where it gets coldish at times
which gloves with heated hand grips
- dilligaf
- Bike: Z900
- 6maniac
- Bike: Z750
Re: which gloves with heated hand grips
G'day - you'll still need a good pair of winter gloves to keep the fingers warm - heated grips still won't warm the back of the fingers if they are out in the airstream ie naked bikes.
Hi mate,
I also have Oxford Heated Grips on my Z1000!
I wear my A* leather summer gloves with them & rarely have my hands got cold.
The heat from the grips radiate through your entire hand & fingers...
My warmers will cook my fingers in winter gloves - if I turn them on high I need to lift my fingers off them every few minutes, so as long as the gloves cover my wrists I stay plenty warm.6maniac wrote:G'day - you'll still need a good pair of winter gloves to keep the fingers warm - heated grips still won't warm the back of the fingers if they are out in the airstream ie naked bikes.
- dilligaf
- Bike: Z900
thanks. I'll stick with the thinner gloves and see what happens.
edit. if anyone is interested alpinestars srs drystar gloves are the go. very light and waterproof.
