The old engine cover..cover chestnut!
IrishPete
Post by IrishPete »
Hi guys,
Have been hearing a lot about this new MA racing rule regarding a requirement of covers to cover your engine covers :shock:
I have a couple of Questions:
1: Do aftermarket covers like those from NRC suffice?
2: Is it just the alternator and timing cover thats needed, or the clutch cover as well, as I've seen covers for the former, but not the latter.
3: If you make your own, what do they have to be made from?
4: For those of you that've made your own, how'd you do it and is it something I can knock together myself with little problem?
Re: The old engine cover..cover chestnut!
Ah yes, that issue.. Its had a bit of discussion on here... :-)
1. Yep, NRC covers are ok, You may have trouble finding them for your bike though as they will be old stock. Keep a look out on ebay.
2. Hmm. the clutch cover you ask.?? That has been the subject of some heated discussion on here. I think the answer is, only if it sticks out further than any other covered engine case.?
3. Materials can be composite ,like Carbon fibre or kevlar - Aluminium or steel.
4. Most of us nade our own. I cut up some carbon fibre sheet I had, but others folded aluminium sheet.
have a read here... :-) in particular the last few pages..
http://www.ksrc-au.com/phpBB3/viewtopic ... lit=covers
IrishPete
Post by IrishPete »
Cheers mate, that made for some interesting reading :shock: :D
