Rear brake 08 zx10r Please explain
- Blurr
Hi all,
I am trying to bleed and adjust the rear brake on the new girl but instead i have gone from a spongy brake feel to none at all.
I adjusted the screw all the way down to bring the pedal up alittle higher and I am using one of those one way valve hoses from supercheap as I am trying to bleed to back brake bleed nipple but I am not getting any results at all. I have even put a clear 6mm hose over the nipple and tried to suck any air bubbles out.
What am I doing wrong or is there something else I can try?
Also what else would cause the loss of feel that I havent mentioned yet?
cheers for the help
cheers for the help
- Tinman
Re: Rear brake 08 zx10r Please explain
Geeez Blurr do you need a hand I'm only down the road sing out if you do mate?
Live 2 Ride!
Honda 2003 Race bike
2009 Mozzie Green ofcourse
http://www.rcutopia.com.au
dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
put the hose over the nipple, put weight on the peddle open up the nipple a bit and as the lever goes down, close the nipple while still keeping pressure on the pedal.
once tight, let the pedal go, and repeat till air bubbles are out.
- 6maniac
- Bike: Z750
Listen to Wattie - he's married and is now a "subject Matter Expert" on nipples! Not sure about brakes, though ?Wattie wrote:dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
- Tinman
6maniac wrote:Listen to Wattie - he's married and is now a "subject Matter Expert" on nipples! Not sure about brakes, though ?Wattie wrote:dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
Live 2 Ride!
i must correct you, since being marries, less nipples now...
its winter you know...
- 6maniac
- Bike: Z750
- Blurr
yeah doing this mate. i even pumped it a few times before releasing the nipple. still now feel.Wattie wrote:dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
going to try again a bit later.
I am off to practice on some different nipples.
- Blurr
lets see how I go tomorrow before I call in the cavalry.Tinman wrote:Geeez Blurr do you need a hand I'm only down the road sing out if you do mate?
- swabio-ACT
Hope they aren't hairy nipples!Blurr wrote:yeah doing this mate. i even pumped it a few times before releasing the nipple. still now feel.Wattie wrote:dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
- Tinman
No probs mate just yell if you need a handBlurr wrote:lets see how I go tomorrow before I call in the cavalry.Tinman wrote:Geeez Blurr do you need a hand I'm only down the road sing out if you do mate?
Live 2 Ride!
- Blurr
it's just winter growth, I always wax in the summerswabio-ACT wrote:Hope they aren't hairy nipples!Blurr wrote:yeah doing this mate. i even pumped it a few times before releasing the nipple. still now feel.Wattie wrote:dont follow the instructions on the "one man bleed kit" it dont work real good on bikes.
- 6maniac
- Bike: Z750
I can feel some monkey paaawwwwn coming on
- IsleofNinja
- State: Western Australia
Blurr wrote:Hi all,
I adjusted the screw all the way down to bring the pedal up alittle higher ...
cheers for the help
Mate you must have at least a little end play between the lever and pushrod / yoke. If you adjust it too much you start pushing the master cyl piston back up into it's bore and close off the compensating port. ... End result is you'll never bleed it..
If you do get all the air out and don't leave a bit (a few mm is enough) of free play the rear caliper will 'pump up' and fry your rotor / pads.
I use highly advanced and really technichal equipment to bleed my rears ;
1 x bottle DOT 4 brake fluid
1 x 8mm ring spanner
1 x index finger (aka one way valve)
1 x garden hose (for clean up)
1 x can Jim Beam n cola (motivation)
06 ZX10r , 95 ZX9r
07 FXST
07 FXST
