Dead ZXR :cry:
- kevindinho
Dead ZXR :cry:
Hi all!
I am having some issues starting my ZXR250, I haven't had the time to take the bike out for two to three weeks so the battery was dead. So i used a jump starter pack to start it up; the bike lights up yet it wont start. Any ideas? could it be just a simple battery replacement or something more serious?
Re: Dead ZXR :cry:
zxr250's can be a real pain to start at the best of times, especially in the middle of winter with a dead battery....
Can you clutch start it?
- mike-s
Re: Dead ZXR :cry:
Step #1, if the electrics crank when you hit the button, drain the carbs and start again.
If you've flooded it then choke off, WOT, crank the throttle for 4-5 seconds, repeat a couple of times and hopefully it'll clear with a nice healthy backfire
Seriously though, draining the carbs is step #1 if it wont kick over.
- kevindinho
Re: Dead ZXR :cry:
I don't know how to clutch start the bike im a serious noob....But i think your right mike-s, i should try drain the carbs. by the way what is WOT??
- woteva
Re: Dead ZXR :cry:
You don't say if the starter is cranking or not ??
If not, check the kill switch or the side stand switch.
- kevindinho
Re: Dead ZXR :cry:
cranking as in making that sound before the engine starts up? everything seems normal besides the battery being flat. When i use the jump starter the lights etc come on, i press the ignition button and it just makes the sound but the engine does not start
- timmyrocks
Re: Dead ZXR :cry:
while your trying to start her up does the exhaust smell fuely? easy way to make shore fuel is getting to there,,,
maby fuels gone bad try topping to tank up with some fresh stuff
good luck cheers Tim
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- kevindinho
Re: Dead ZXR :cry:
How do i drain the carbs?? anyone?
- ZX7RRR
- Bike: ZX7R
Re: Dead ZXR :cry:
Hi Kevin!
U last posted a few days ago, so I hope u fixed ur problem.
If not, try this........
#1. Turn key 2 start
#2. DO NOT touch throttle
#3. DO NOT touch choke.....leave it off
#4. with or without jump starter, press ur start butten....keep it down ( starting ) for a few seconds, whilst cold it shouldnt start......so it's turning over....this should clean ur carbs
#5. Now choke on, throttle a few time's and start her up
This almost always works 4 me ......when she has sat around 4 a while...
Good luck!!!!!!!
Good luck!!!!!!!
ZX9-Rrrocket
Re: Dead ZXR :cry:
You should prob take your battery out and charge it properly. A jump start pack could exceed the the usual alternator charging and protected voltage and become unregulated and spike... Zapping protective circuitry. (fuses,diodes etc). A host battery is a higher voltage than the 1 getting charged...kevindinho wrote:Hi all!
- kevindinho
Re: Dead ZXR :cry:
Thanks for the advice ZX7RRR I've tried that already but it still won't go. So I've sent my bike to Bike Biz to check it out
should be sweet in a couple of days!
