Head lift stand for my ZX7r
WRCKLS
Post by WRCKLS »
Hey guy's
Can any one point me in the right direction to where i can get a headlift stand for 96 ZX7r. I've tried one from my work mate but it just keeps slipping off. Is it true that i need to get the rear on a stand too?
Re: Head lift stand for my ZX7r
Yep.... you must have a rear stand to use a head lift stand, try contacting Pete at Kaneg a site sponsor & all round good guy ;) http://www.kaneg.com.au
Tack
Post by Tack »
I got one from kaneg for mine. The 1996 needs a larger headstock pin then the earlier models.....I have a 91 ZXR750 as well...and the stand came with various sized pins but not one large enough for the 96 model. I should probably measure it!
WRCKLS
Post by WRCKLS »
Yea, i had a feeling that the head pin's my mate gave to me wasn't big enough.
I think it's about a 21mm head pin
frog
Post by frog »
Correctamundo, the headstem hole on a 7R is huge, HUGE I tell ya :lol:
Oh and while it is DEFINITELY safer to have a rear stand it is not absolutely necessary. ;)
Jedi of the darKside
Just because you can ride, doesnt mean you should. My reason on this earth is an example to others what NOT to do.
triway
Post by triway »
Where are you located?
I have one you can buy cheap.
PM me if interested.
www.techspec-aus.com.au
www.trackdaypro.com.au
Mitch
Post by Mitch »
I have the Kaneg head lift stand I just use the largest pin it came with, works no problem!
My ZX7R
My ZX7R
www.bigmitchracing.com
